12-07-2016, 13:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Ukraine
Member: 74053 Status: Online Thanks Meter: 75 | MRT FAQ (Beta version) I ask all to correct and supplement this manual, the only proven solution! Start. 1.MRT work requires an internet connection, all the errors at startup are related to his lack of or poor quality. 2. The dongle does not require any special driver, the system is defined as a basic disk. The program requires no installation. 3. ..... Work. 1. Xiomi Note 3 Pro (kenzo) User Lock. a) Select Xiaomi tab / Unlock password BL Lock phones b) Enter phone in recovery mode. Power off. Press volume + and Power key, after the logo appears release the power button, after entering the recovery release the volume + button, if not, check the connection, the command "adb devices" answer should be "adb sideload" Remove Account (Acc) ........ MTK Tool. http://forum.gsmhosting.com/vbb/f492...anual-2156016/ Last edited by Mishel; 12-07-2016 at 14:02. |
The Following 5 Users Say Thank You to Mishel For This Useful Post: |
12-08-2016, 09:22 | #3 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | MRT team said "World First All Of Xiaomi New Device 2015 up to 2016 MRT Dongle Supported for Password Removal". So you need a detailed description of the algorithm in the performance, it will help promote the program and release the support of the need to respond to basic questions. And who reads WIKI |
12-09-2016, 08:56 | #4 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | Thank you for your endless patience and correct English Mr. A^A Xiomi Note 3 Pro (kenzo) Remove Account (Acc) Step 1 Quite simple step actually: I assume all drivers are installed properly (CHECK!) 1. Don't open MRT yet, keep it close 2. Plug the cable into the phone, and put it on EDL mode 3. Make sure it's properly detected in device manager 4. Open MRT, pick Redmi Note 3 from drop down list 5. Finally click Remove Account Done, turn it on, enable adb, and proceed Remove APK steps. Step 2 No need root at all. Windows 10 suported. Better using version 7.3.2 for higher success rate, especially for Note 3 Pro Enable USB debuging, get user permissions from phone . 1. Make sure adb driver that installed in your system is the latest one. 2. Don't open MRT yet 3. Enable ADB in the phone (you know how to do this one) 4. Plug the cable into the phone, make sure phone properly detected in the device manager 5. Open ADB CMD prompt, and type adb devices, look at your phone screen, there should be an ADB notification ask for manual permission 6. Dont forget to TICK (always give) and click OK to allow it 7. Open MRT, finally click Remove APK Screenshots and original thread http://forum.gsmhosting.com/vbb/f492...filed-2164863/ To be continued.... Last edited by Mishel; 12-09-2016 at 09:03. |
The Following 4 Users Say Thank You to Mishel For This Useful Post: |
12-19-2016, 10:39 | #6 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | If you get errors when removing phone code Meizu M3 Note select M3s model, it works! http://forum.gsmhosting.com/vbb/f492...wered-2137590/ |
The Following User Says Thank You to Mishel For This Useful Post: |
01-02-2017, 20:12 | #7 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | If you get an error " >>> Sending Auth File To Mobile ... Success >>>> Trying Connect to Service verification data ... Connect to Service Fail, Please re-run the software and try again ... Fail" server based authentication service is off-line, try again later, perhaps Mr. zhulianqi shut own laptop Good news: Date: 22nd Dec 2016 Service 2 and move the service, now run the software faster. Support MTK remove FRP <OLD CPU and new CPU all are support. Support oppo r9s a57 and more <qualcomm CPU>. Adjust Oppo R7 full <like r7s r7p....> all the Oppo form R7 start MTK chip Support Vivo X9 Y55a and others new mobile Support Meizu note5 5 6s x and more MTK CPU support MT6757 Last edited by Mishel; 01-02-2017 at 20:20. |
01-06-2017, 22:06 | #8 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | Xiaomi M3s Mi account deleted (ver. 1.55) 1. Downgrade to land_global_images_V7.5.8.0.MALMIDE_20160712.0000. 26_6.0_global 2. Enable USB debugging in developer options and OEM unlock (optional) 3. Enable instaliations from unknown sourses 4. Connect phone and allow debugging autorisations, disconect! 5. Run MRT 6. Click "Remove APP" 7. Connect phone |
The Following 3 Users Say Thank You to Mishel For This Useful Post: |
01-11-2017, 12:39 | #10 (permalink) |
Member: 74053 Status: Online Thanks Meter: 75 | comprehensive guide to flashing Redmi Note 3 (MTK) via Flash tool http://forum.gsmhosting.com/vbb/f492.../#post12271088 |
01-27-2017, 20:20 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
02-01-2017, 16:33 | #14 (permalink) | ||
After flashing china 7.3 from support MRT was removed two apk as on screenshot from post 13: But: - now I can't reset phone, - can't update phone, - no market, - no any languages except English and China. Is it really solution that cost 100$? | ||
03-07-2017, 20:24 | #15 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Its just need to fix ! let me know which tool can do like MRT Dongle for redmi note 4 and redmi 3/3x/ etc As long as is ok...MRT Have many success report! Which tool can do safe format ? like this http://forum.gsmhosting.com/vbb/f492...eport-2200480/ no tool have a brave doing like this i never see like this in my section MRT Dongle well done !! You can make money every day with mrt dongle ... Do format without dead device and safe imei in oppo set ...etc ( its world first ) you can see in success report this section http://forum.gsmhosting.com/vbb/f492...k-etc-2067525/. http://forum.gsmhosting.com/vbb/f492...-pack-2158415/ http://forum.gsmhosting.com/vbb/f492...-pack-2189259/ http://forum.gsmhosting.com/vbb/f492...orted-2134329/ http://forum.gsmhosting.com/vbb/f492...eport-2201240/ http://forum.gsmhosting.com/vbb/f492...umang-2177800/ http://forum.gsmhosting.com/vbb/f492...-pack-2143986/ http://forum.gsmhosting.com/vbb/f492...-pack-2158415/ - which one can do this? http://forum.gsmhosting.com/vbb/f492...-pack-2148118/ http://forum.gsmhosting.com/vbb/f492...-done-2186054/ - Which one can do this? ...and many more !!! Unlock password just one click is our world first and Many other world first features in other brand As you can see..In Every features of MRT other product will following us Be grateful people...have a nice day . Last edited by .::ARD::.; 03-07-2017 at 22:21. |
The Following 2 Users Say Thank You to .::ARD::. For This Useful Post: |
