08-07-2009, 04:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 1200 cyclone reroore hwk flashin ok but cyclone this errore Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0000949 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D20001EA Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.18v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.10v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 60 products, Filtering DCT4 Products - wait... 12 Products left after filtering. Ready. Retrieving Variants for Product RH-99 - wait... 1 Variants Retrieved Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 6.781s Check Flashing Bus finished Programming data for IMEI: 352904026104240 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Programming FLASH data... FLASH data Programmed OK Programming UEM data... UEM data Programmed OK Terminating flash session Write UEM finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 6.515s Check Flashing Bus finished Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.910, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 845259E24230C61847B9FEE193 MSID-Plain: 3E4EBAE9009FBC22A8000000 FAID-Crypted: C2ABD414CAE1FAC13C1335B8 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 64.125s Writing 146 blocks... All blocks written OK! Time taken 13.547s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh990_nai5.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84632CD8422984D33CA362A646 MSID-Plain: 3E4EBAE9009FBC22A9000000 FAID-Crypted: F2685D9C2551CE2AAC1501C9 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.32s Writing 10 blocks... All blocks written OK! Time taken 0.891s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Failed to disable VPP -> No answer from CBUS Processing Flash Image Failed -> Failed to disable box VPP Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_05.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Box VPP disabled Processing Flash Image Failed -> Set Flashbus baudrate failed Failed to Flash -> Problem with processing CNT Image file |
08-07-2009, 09:41 | #4 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | I dont know its CNT file or what here is the file can you confrm this? C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91mh If no then tell me what is a CNT? hope you'll solwe my problm |
08-07-2009, 14:13 | #5 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | 1200 cyclone errore 1200 jaf box flasing ok 1200 hwk flashing ok cyclone errore UPP ID: 2292 [HW_UNKNOWN] rh99_05.91mh, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Box VPP disabled Processing Flash Image Failed -> Set Flashbus baudrate failed Failed to Flash -> Problem with processing CNT Image file |
cyclone box can't change to main mode [SOLVED - Thanks HRCO] | banalven1 | Cyclonebox | 5 | 03-29-2010 09:34 |
1200 cyclon erore help | vaghubha_sodha | Cyclonebox | 4 | 08-17-2009 07:45 |
1200 cyclone errore help | vaghubha_sodha | Cyclonebox | 3 | 08-13-2009 06:44 |
1200 cyclone errore help | vaghubha_sodha | Cyclonebox | 6 | 08-08-2009 08:06 |
1200 cyclone errore help | vaghubha_sodha | Nokia Hardware & Hardware Repair | 3 | 08-07-2009 05:44 |
