02-23-2010, 14:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | 1200 rpl fault Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0000075 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D0000340 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.95v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 8.328s Check Flashing Bus finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Searching for CBUS Loader: UEM u3_uem.fia, Type: Algorithm, Rev: 6.5.18.0, Algo: UEM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 8463C7144B6E6116D4F2CAE24B MSID-Plain: 2C40BAE9000249A3AA000000 FAID-Crypted: 6E8AEEC78E4738309FF41B93 CBUS Loader Spawned OK! Failed to Read UEM IMEI -> 'A' is not a valid integer value is there any sloulation for this fault . |
1200 strange fault | yakkathali | Nokia Hardware & Hardware Repair | 5 | 01-17-2012 08:07 |
1200 charging fault.............. | dhineshh | Nokia Hardware & Hardware Repair | 1 | 03-18-2010 07:33 |
1200 strange fault........... | dhineshh | Nokia Hardware & Hardware Repair | 0 | 04-04-2009 14:37 |
