04-21-2009, 04:21 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: santiago city,philippines
Member: 655303 Status: Offline Thanks Meter: 117 | 1202 white screen revived by cyclone box. Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application Box Serial Number:megatech10 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: megatech10 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.11v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Backing up Flash IMEI... Failed to backup Flash IMEI, but continuing Pre-flash tasks finished Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh112_003.000, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 28.16s Writing 148 blocks... All blocks written OK! Time taken 11.985s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh1120_nai03.00aa, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 1.375s Writing 9 blocks... All blocks written OK! Time taken 0.687s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh112_003.00aa, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01240000-0x0124FFFF] Erasing NOR Region [0x01250000-0x0137FFFF] Erase taken 8.985s Writing 68 blocks... All blocks written OK! Time taken 5.468s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Unlocking... MCU Version MCU Date Product Manufacturer IMEI 0, 14-11-08, RH-112, (c) NMP Asic 11 HW Signature 838B914BF41C65D7 Simlock Server 5ƒ‹‘Kôe×ÿÿ Simlock Key 0010100000000000 Simlock Profile 0000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003564070281393500 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: _ Unlock data not found, proceeding with no-patch unlock... Unlock thread finished, continuing... Post-flash tasks finished... Flash successfully finished! |
The Following User Says Thank You to megatech10 For This Useful Post: |
04-21-2009, 08:47 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
plz cyclone team solve this error Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP few mobiles after flash no ringtone ............. also check 6030 after flash can't play few ringtones ? sign on that | |
The Following User Says Thank You to hasnain For This Useful Post: |
1202 white screen. | fawad85 | HWK | 2 | 08-30-2009 08:20 |
N96 dead but no revive with cyclone box | bigaquila | Cyclonebox | 5 | 08-07-2009 07:10 |
<< 6300 revived by cyclone >> | alfox | Cyclonebox | 22 | 06-23-2009 22:48 |
2680s contact service revived by cyclone box | megatech10 | Cyclonebox | 3 | 04-21-2009 04:20 |
Dead N95 8gb revived by cyclone box | Mr.3. | Cyclonebox | 0 | 03-27-2009 13:53 |
