2610b ver5.65 " CONTACT RETAILER " how can I fix it please helpI have this 2610b ver. 2610b from Tmobile U.S that has a " contact retailer " every time I turn it on, This is my first tim to encounter this problem and I don't know what to do please help. Here is the logs from Cyclone box: MCU Version V 05.65 MCU Date 06-07-07 Product RH-87 Manufacturer (c) Nokia. IMEI 011288000283828 Mastercode 702226270 IMEI Spare 0A11820800828302 IMEI SV 0311820800828342F2000000 PPM V 05.65, 06-07-07, RH-86_87, (c) Nokia. , MTM PSN RYL216013 Product Code 0552997 Module Code 0203496 Basic Product Code 0550675 PSD 0000001800000000 HW 7200 UEM 1328 UPP 12352 RFIC 0500 DSP P05w45.v49 LCD ELBE Failed to read info -> Failed to read SP info and this is from JAF: Powering the phone... Reading... MCU SW version: V 05.65 06-07-07 RH-87 (c) Nokia. HW version: 7200 PCI version: UEM version: 1328 UPP version: 12352 RFIC version: 0500 DSP version: P05w45.v49 LCD version: ELBE PPM version: V 05.65 06-07-07 RH-86_87 (c) Nokia. MTM Content Pack version: Content: TMO US v1 23-07-07 RH-87 (c) Nokia. Production serial number: RYL216013 Product code: 0552997 Module code: 0203496 Basic production code: 0550675 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 011288000283828 IMEI spare to net: 0A 11 82 08 00 82 83 02 IMEI SV to net: 03 11 82 08 00 82 83 42 F2 Master Code: 7002226270 Failed reading simlock data... Phone type: RH-87, Software version: 05.65, Language Pack: MTM User code: 12345 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-87.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.65 06-07-07 RH-87 (c) Nokia. HW version: 7200 PCI version: UEM version: 1328 UPP version: 12352 RFIC version: 0500 DSP version: P05w45.v49 LCD version: ELBE PPM version: V 05.65 06-07-07 RH-86_87 (c) Nokia. MTM Content Pack version: Content: TMO US v1 23-07-07 RH-87 (c) Nokia. Production serial number: RYL216013 Product code: 0552997 Module code: 0203496 Basic production code: 0550675 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 011288000283828 IMEI spare to net: 0A 11 82 08 00 82 83 02 IMEI SV to net: 03 11 82 08 00 82 83 42 F2 Master Code: 7002226270 Failed reading simlock data... <<<<<<<< pero ito failed! Phone type: RH-87, Software version: 05.65, Language Pack: MTM User code: 12345 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-87.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
Mate! Try to full erase then flash write good pm then unlock. |
Thanks for reply though |
..::Brother to first erase and again flash same version but use jaf box so unlock and write good pm so your proble solved::.. |
Just unlock your phone again, and It'llbe fine. |
