Member: 583353
Thanks Meter: 259 | 2680s-2b RM-393 after flashing phone now dead... i tried different version but still same problem even RM-392 flashfile same result,unit is working from USA before i flash need to convert but after flash phone now dead....
logs: Quote:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application
Box Serial Number: nelsky
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: nelsky
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.19v PASSED
MCU Voltage 3.25v PASSED
Core Voltage 1.80v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.11v PASSED
Box VPP disabled
VPP Voltage 0.09v PASSED
Internal Box VPP Enabled
VPP Voltage 5.04v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.09v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting UPP...
UPP ID: 3162 [HW_UNKNOWN]
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
PLL Factor: 3
FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221
Signature: AD7EB61B00FF10400000000000000000
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 4Kbits
u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.00V
Terminating flash session
Boot operation took 6.391s
Check Flashing Bus finished
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 220 products, Filtering DCT4 Products - wait...
30 Products left after filtering. Ready.
Retrieving Variants for Product RM-393 - wait...
5 Variants Retrieved
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
rm392__04.91.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[1]: 0x0001317E @ 0x02000000, AMD, SectorSize: 128kB, Ext: 00419221
Flashbus Read baud set to 51Kbits
Nominal VPP Voltage: 9V, Detected: 0.04V
MSID-Crypted: 84D49730603332F62AE0CFD78E
MSID-Plain: 2C40BAE9005B049AA9000000
FAID-Crypted: 091E4FE3C2109BD3FC2C6A6B
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01CFFFFF]
Erase taken 55.578s
Writing 377 blocks...
All blocks written OK! Time taken 219.937s
Box VPP disabled
Booting UPP...
rm392__04.91.image_us_ub, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 845DB7C98B9496FA8D6DEC28BB
MSID-Plain: D26EBAF1005B049AAA000610
FAID-Crypted: B15EB390042D4545BDB83766
Erasing NOR Region [0x02180000-0x02E7FFFF]
Erasing NOR Region [0x02E80000-0x02FBFFFF]
Erase taken 71.328s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 168 blocks...
All blocks written OK! Time taken 44.641s
Terminating flash session Extracting Content Package...
CP Extract Failed -> Phone not detected
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rm392__04.91.ppm_ub, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8433BA8A16DB2EA0522DA84CFC
MSID-Plain: 3E4EBAE9005B049AA8000000
FAID-Crypted: 6A8B9592372ADF0E4ADBC877
1 Region(s) to erase
Erasing NOR Region [0x01D00000-0x0217FFFF]
Erase taken 21.797s
Writing 74 blocks...
All blocks written OK! Time taken 44.63s
Box VPP disabled
Processing post-flash tasks...
Post-flash tasks finished...
Flash successfully finished!
| need to revive the phone A.S.A.P.
pls help...
br, |
