Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-24-2010, 01:33   #1 (permalink)
Member: 91558
Thanks Meter: 66
cant flash n81 8gb
@moulnisky
please need help cant flash the phone,now is dead after stop at erasing process now phone dead and cant flash
Writing CMT ADA Certificate...
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process RM179_20.0.056_prd.C00
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing RM179_20.0.056_prd.C00 (CMT)...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1170010AC46700525B262791CFDC86F2F513EE20
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C
CMT_BOOT_ROM_CRC: A8C1D671
CMT_SECURE_ROM_CRC: 3E691FF8
RM179_20.0.056_prd.C00, Type: Flash Image, Algo: BB5, XSR 1.5
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 10
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND
EraseArea[0,CMT]: 0x00B80000-0x05F7FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 1.516s
Writing all blocks...
please need help
Old 02-24-2010, 02:01   #2 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
TX2 line problem, are you using the TX2 adapter ?
Check cable, check ( redo ) solders in TX2 adapter, clean contacts in phone PCB.
do an " Check Flashing Bus " to see if TX2 is working properly.
N81-8GB RM179 After Full Flash Cant On!!! - SOLVED danielkoh Cyclonebox 4 08-01-2009 05:17
error while flashing n81 8gb M-taheri Cyclonebox 3 07-13-2009 20:13
Flashing N81 8gb with Ipmart rj48 Cables.. Work Perfect!! bestncheap MT-BOX 4 01-01-2008 10:13
can new suite flash N81 8gb?? noktune_win HWK 0 11-03-2007 09:57
Page generated in 0.13726 seconds with 9 queries
