06-24-2009, 12:51 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Gwardamanga
Member: 450509 Status: Offline Sonork: 100.1590256 Thanks Meter: 114 | 5310 unlock successfull with cyclon box here is log Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C000038D HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D0000152 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.09v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.04v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 115 products, Filtering BB5 Products - wait... 35 Products left after filtering. Ready. Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 115 products, Filtering BB5 Products - wait... 35 Products left after filtering. Ready. Retrieving Variants for Product RM-320 - wait... 24 Variants Retrieved MCU Version V 05.81 MCU Date 06-02-08 Product RM-303 Manufacturer (c) Nokia IMEI 352044xxxxxxxx Mastercode 311372130 IMEI Spare 3A25400492700509 IMEI SV 3325400492700529F7000000 PPM V 05.81, 06-02-08, RM-303, (c) Nokia , C CNT Content: o2_pre_uk_red, V 05.81, 06-02-08, RM-303, (c) Nokia , , PSN DUA416270 Product Code 0556508 Module Code 0203414 Basic Product Code 0544850 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1000 RFIC 064c0609 DSP ICPR71_08w03_3 LCD SEIKO BT 2222-143 Simlock Server SIMLOCK SERVER Simlock Key 2341000000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14600212F8640254B7613906B576218F9AC5470D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D APE Subsystem Not Found CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Not Found CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished BB5 Unlock Started... MCU Version V 05.81 MCU Date 06-02-08 Product RM-303 Manufacturer (c) Nokia IMEI 35204402xxxxxx Mastercode 311372130 Simlock Server SIMLOCK SERVER Simlock Key 2341000000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14600212F8640254B7613906B576218F9AC5470D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14600212F8640254B7613906B576218F9AC5470D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... MCU Version V 05.81 MCU Date 06-02-08 Product RM-303 Manufacturer (c) Nokia IMEI 352044029075092 Mastercode 311372130 Warning: Failed to read SP Info, Assuming defaults BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected BB5 Unlock Started... MCU Version V 05.81 MCU Date 06-02-08 Product RM-303 Manufacturer (c) Nokia IMEI 3520440xxxxxxx Mastercode 311372130 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 3434303239303735 Simlock Profile 3039320020202020 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14600212F8640254B7613906B576218F9AC5470D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14600212F8640254B7613906B576218F9AC5470D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... MCU Version V 05.81 MCU Date 06-02-08 Product RM-303 Manufacturer (c) Nokia IMEI 3520440xxxxxxxxx Mastercode 311372130 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! |
The Following User Says Thank You to imran_mobi For This Useful Post: |
06-24-2009, 13:40 | #3 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 212683 Status: Offline Thanks Meter: 115 | gr8............................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ...........................................cyclone box |
2330 v6.75 unlocking successfull with Cyclone | invisible990200 | Cyclonebox | 1 | 09-12-2009 11:35 |
are nokia 5800 unlock sported with cyclon box | themobileshop | Cyclonebox | 3 | 08-31-2009 17:14 |
N85 unlock smothly with cyclone box just for refference | shawgsm | Cyclonebox | 3 | 07-12-2009 04:43 |
E63 unlocked ok with cyclone box | yasermalik | Cyclonebox | 3 | 07-07-2009 07:22 |
nokia 2760 unlock done with cyclone box v 6.82 | yasermalik | Cyclonebox | 1 | 04-26-2009 07:59 |
