07-04-2009, 19:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | 5800 RM-428 no unlock with cyclone box! Hi all: I cant unlock 5800 with cyclone box. Any solution? This version is supported? Thank you very much. Best regardsBB5 Unlock Started... MCU Version V ICPR72_09w02.3 MCU Date 26-01-09 Product RM-428 Manufacturer (c) Nokia IMEI 35934xxxxxxxxxx Mastercode 343535132 Simlock Server SIMLOCK SERVER Simlock Key 7300200000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 73404F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock[3,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock[4,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock[5,1] State: CLOSED Type: MCC-MNC Data: 33203F Simlock[6,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock[7,1] State: CLOSED Type: MCC-MNC Data: 74000F Simlock[8,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock[9,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock[10,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock[11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock[12,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock[13,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock[14,1] State: CLOSED Type: MCC-MNC Data: 71606F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CC0001919760052F697169052831B639EA26698 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CC0001919760052F697169052831B639EA26698 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Bypassing SX4... Booting RAP... BB5 Unlock Failed -> Failed to Boot / Prepare Phone |
07-04-2009, 19:41 | #2 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Colombia Unlock
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Friend trying to follow these using the adapter at that moment the process enecendido press and I said that is true is true ... Regards oscar jr |
07-05-2009, 04:15 | #3 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Hi! This version is supported?.. I tried with external battery and without battery.. anyone tested this version? the steps I follow are: BB5, security and unlock. Thanks! Best Regards |
07-05-2009, 06:36 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | yes version is supported for sure make sure u used TX2 adapter and good cable ...better check flashing BUS first and also then create RPL from phone |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
07-08-2009, 14:46 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | AFTER POPUP "Calculate NCK CODE"? will show up wait 5-10 seconds adn then click yes/no |
The Following 3 Users Say Thank You to karwos For This Useful Post: |
07-13-2009, 02:11 | #6 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | OK!! Phone 5800 unlocked done!! Cyclone is the best!!! Thanks Cyclone Team!!!!!! Sorry, but I closed the software before I copy and paste the log. Where are the logs of operations? Best regards |
07-13-2009, 09:51 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | i unlock this phone many times and no problem.. dont use adater use normal cable if you have for me i use UFC cable see here for the pinout http://forum.gsmhosting.com/vbb/showthread.php?t=786326 |
07-21-2009, 19:38 | #10 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 49
Member: 57544 Status: Offline Thanks Meter: 1 | BB5 Unlock Started... MCU Version V ICPR72_08w41.1 MCU Date 22-10-08 Product RM-356 Manufacturer (c) Nokia IMEI 354183025885308 Mastercode 6433724440 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 64710F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC001158B720052C0B423C509B5203387FF0E9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC001158B720052C0B423C509B5203387FF0E9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... #pw+816983512749739+1# #pw+394444886853723+2# #pw+443476308564915+3# #pw+316980984298828+4# #pw+607538779896029+5# #pw+487307364826023+6# #pw+296370259535590+7# Sending NCK Code (Level 7).. NCK Accepted! Phone unlocked OK! MCU Version V ICPR72_08w41.1 MCU Date 22-10-08 Product RM-356 Manufacturer (c) Nokia IMEI 354183025885308 Mastercode 6433724440 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 20810F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 20810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 64710F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 64710F Simlock NCK #pw+296370259535590+7# Unlock finished! thx cyclone box u are the best |
08-14-2009, 06:01 | #14 (permalink) |
Moderator Join Date: Nov 2006 Location: Amazonas, Brasil. Age: 57
Member: 394257 Status: Offline Sonork: 100.1583308 temp.disabled Thanks Meter: 979 | See here: http://forum.gsmhosting.com/vbb/show...ghlight=rm-428 Use search to save you time and forum space. B;r |
N95 Rm-159 no unlock for Cyclone Box Bulk Update Released | zsolt1 | Cyclonebox | 3 | 08-11-2009 05:37 |
N96 dead but no revive with cyclone box | bigaquila | Cyclonebox | 5 | 08-07-2009 07:10 |
N95 RM 159 Successfully Unlocked only Cyclone Box | Qaisar Mahmood | Cyclonebox | 12 | 07-06-2009 14:06 |
!!! 5800 unlock with cyclone box !!! | sirbigman | Cyclonebox | 21 | 06-23-2009 04:59 |
6103 rm-162 SW version 4.77 dead after UNlock with Cyclone box | residentdenuevo | Cyclonebox | 6 | 04-15-2009 10:34 |
