09-11-2012, 14:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai Age: 31
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | 6300 imei 12345 any way to get it back (SOLVED) |
09-11-2012, 14:09 | #2 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | if u fash with cyclone and aftere that show imes 12345 u should .go to security click after that auto recovery ime npc .self will be done |
09-11-2012, 17:25 | #3 (permalink) |
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | it was not flash with cyclone it was flash with mx-key.. now any solution with cyclone?? there no backup of rpl ... so wht 2 do now??? |
09-12-2012, 06:52 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | before anything please post the infos of each mobile: these mobiles were available in double simlock format (Both sl3 and sl2) if you by mistake flashed an sl2 as sl3 (so the actual firmware is 5x.xx) or an sl3 as sl2 (so actual firmware is <49.99) the imei became 1234560... if you did so, do back-up of PM and rpl the flash it with the related version of firmware then the mobile will get back its imei and, if lucky enaugh to have still a proper simlock infos in them (if sl3 version as for sl2 is enaugh rebuild it unlocking the mobile using the rpl method) all will be fine BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
