05-17-2009, 23:02 | #1 (permalink) |
Product Supporter Join Date: Aug 2003 Location: Inside My Phone
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | 6500 write rpl.... problem Erasing Security... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request CMT NPC Not erased Restarting MCU... Failed to Write RPL File -> Phone not detected full flash run ok but phone on white display and off... this log is after erase. someone know any solution? BR. kikodog. |
05-18-2009, 07:00 | #2 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
and which format u calculated RPL? | |
05-18-2009, 08:12 | #5 (permalink) |
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | dont know if sl2 or sl3 already come to my have in bad condition.. this time i flash with sl2 firmware but i will flash with sl3 now and post results just give me some minutes. |
05-18-2009, 08:25 | #6 (permalink) |
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | flashing with sl3 and some results Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm240__59.60.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm240__59.60.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x01480000-0x015FFFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0147FFFF, NOR Waiting 320s for erasure finish... Erase taken 5.46s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 119.906s Restarting MCU... Processing rm240__59.60.mcusw (APE)... Processing rm240__59.60_ism_001.image_c_uk_tmo_uk2_silver_v4 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm240__59.60_ism_001.image_c_uk_tmo_uk2_silver_v4, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D Started group flash erase EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR EraseArea[0,CMT]: 0x01CC0000-0x01FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 8.16s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 69.313s Restarting MCU... Processing rm240__59.60_ism_001.image_c_uk_tmo_uk2_silver_v4 (APE)... Processing rm240__59.60.ppm_ctm (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F rm240__59.60.ppm_ctm, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D Started group flash erase EraseArea[0,CMT]: 0x01600000-0x01CBFFFF, NOR Waiting 320s for erasure finish... Erase taken 1.562s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 37.157s Restarting MCU... Processing rm240__59.60.ppm_ctm (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ? Skipping RPL decryption... Erasing Security... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D APE Boot skipped on user request CMT NPC Erased Restarting MCU... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Writing Superdongle key... Superdongle Key NOT ACCEPTED ! Writing CMLA key... CMLA Key NOT ACCEPTED ! Writing WMDRM PD Data... WMDRM PD Data NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D APE Subsystem Not Found CMT NPC Erased CMT NPC Written CMT HWC Erased Failed to Write RPL File -> Failed to write CMT HWC certificate now rpl write some... now i can read some info from phone MCU Version V 59.60 MCU Date 21-11-08 Product RM-240 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value now writen full pm with sx4 bypass... Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_BT_WAKEUP_TEST Failed to make Selftests -> Phone is not responding for Selftest Request Last edited by kikodog; 05-18-2009 at 08:33. |
05-18-2009, 08:46 | #7 (permalink) |
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | Working on PM... Configuration Key - Found Failed to Create RPL From PM -> Access violation at address 0058B2B0 in module 'Cyclone.exe'. Read of address 00000000 trying convert 120pm to rpl write pm almost sucess lol after remove hwc data from rpl CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request CMT NPC Erased Restarting MCU... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock NOT ACCEPTED ! Writing Superdongle key... Superdongle Key NOT ACCEPTED ! Writing CMLA key... CMLA Key NOT ACCEPTED ! Writing WMDRM PD Data... WMDRM PD Data NOT ACCEPTED ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C80020AABC34F504E54362C99C20D20B53A4B18 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D APE Subsystem Not Found CMT NPC Erased CMT NPC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! MCU Version V 59.60 MCU Date 21-11-08 Product RM-240 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value MCU Version V 59.60 MCU Date 21-11-08 Product RM-240 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value when flashing Warning: PAPUBKEYS Hash Missing! when rpl PAPUBKEYS Hash for CMT: 2B2A191B54288A818699B64E68916FE1E6A8562D makes any difference? on write flash? possible emulate? WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... how i know if first found PAPUBKEYS are good? Last edited by kikodog; 05-18-2009 at 08:52. |
05-18-2009, 08:46 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Make a Full erase of ur Phone with Uni RAP erase file and Flash to Sl2 Normal Last FW i think 9.60 itis Now First try to write RPL and see what it says tick first plain rpl then untick and try writing then proceed with PM upload or sx4 procedure |
05-18-2009, 09:06 | #10 (permalink) |
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | rm240__59.60.mcusw alreeady flashed with that see logs and cyclone cant erase.. i already erase with jaf last night. with sl3 firmware phone response... with sl2 phone info not work. |
05-18-2009, 09:26 | #11 (permalink) |
Member: 37736 Status: Offline Sonork: 100.108250 Thanks Meter: 222 | MCU Version V 09.60 MCU Date 21-11-08 Product RM-240 Manufacturer (c) Nokia IMEI 353077028379692 Mastercode 2557734065 IMEI Spare 3A35700782736909 IMEI SV 3335700782736969F7000000 PPM V 09.60, 21-11-08, RM-240, (c) Nokia , C CNT Content: c, V 09.60, 21-11-08, RM-240, (c) Nokia , PSN CZA393290 Product Code 0543754 Module Code 0203327 Basic Product Code 0543753 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1000 RFIC 17141715 DSP ICPR71_08w30 LCD SEIKO BT 2222-143 Simlock Server SIMLOCK SERVER Simlock Key 2680300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 26803F cyclone really rocks Last edited by kikodog; 05-18-2009 at 09:34. |
5130 write rpl problem! | Byte | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 20 | 07-21-2009 06:34 |
u900 write rpl problem??? | kaaniletisim | UST Pro II | 1 | 09-22-2008 15:40 |
N91 Write rpl problem | majidjony | MT-BOX | 4 | 12-07-2007 10:00 |
N91 write rpl problem | thxseto | MT-BOX | 3 | 09-10-2007 09:59 |
