07-11-2009, 11:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | any way to use UFC with cyclocne? any way to use UFC with cyclone? |
07-11-2009, 11:27 | #3 (permalink) | |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
and cyclone pinouts are same as jaf/ufs . dont forget to attach yellow adopter with bb5 fones | |
07-11-2009, 14:05 | #4 (permalink) | |
Member: 239168 Status: Offline Thanks Meter: 104 | Quote:
any tips to get test mode using UFC in cyclone? | |
07-11-2009, 14:23 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You must be carefull as some UFC cables have an error in the assembling so the values are inverted - samples When you put the selector on 3.3k you have instead 10K When you put the selector on 5.1k you have instead 7.5K When you put the selector on 7.5k you have instead 5.1K When you put the selector on 10K you have instead 3.3K Remember as well to use the 8Pin connector if your UFC is the combo one connected to the Yellow cables (TX2 adapter) working with the BB5. If you have problem to get a proper local mode before doing any operation go in the TAB BB5/Flash and click on "check flashing bus".. it will help a lot. These problems disappear using a power solution like TMA adapter or similar. BR Alex |
is there a way to use ufc 10 pin on cyclone | oktay50000 | Cyclonebox | 3 | 05-09-2009 15:36 |
=== is it any way to use Sx4 with out Net === | Faisal_Computer | MT-BOX | 11 | 12-26-2007 16:04 |
any way to use 256 mb in p900 | Javajohn | Sony Ericsson Hardware Repair | 0 | 03-29-2006 08:30 |
Is there any way to use x426 in India | mukteshwar | SYSOL Platform | 0 | 12-07-2004 09:29 |
is the any way to use Sendo M550 for pc GPRS connection? | alexzzander | NEC | 0 | 12-24-2003 01:13 |
