09-20-2012, 15:12 | #1 (permalink) |
Major Poster Join Date: Jul 2008
Member: 808204 Status: Offline Sonork: eagleyezzz Thanks Meter: 2 | C1-01 not reading further ... any solution sir ? Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0004406 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01 Initializing security card... Card Serial Number: D0020525 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.894GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 27 products, Filtering BB5 Products - wait... 11 Products left after filtering. Ready. Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Sending User Abort Signal... Sending User Abort Signal... Phone not detected at USB -> User Abort Proceeding with Recovery Mode... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Recovery Mode Failed, storing Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm607__06.15.mcusw (XGold2)... Checking rm607__06.15.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020603010100FF [PBL] : Ready not reading further ... any solution sir ? first time it was flashed OK but second time ..... need help thanx |
