![]() | #46 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.50, (Dec 24 2010 18:30:25, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000074A HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D0000346 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.85v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-675_012.004_79.92_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process RM-675_012.004_79.92_prd.core.fpsx Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-675_012.004_79.92_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 24A00206B09C034442647FC545736323FECBA001 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_012.004_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FEC ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Processing Flash Image Failed -> Failed to send Certificates Failed to Process all Image files -> Failed to process RM-675_012.004_79.92_prd.core.fpsx |
![]() | #47 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,055 | Warning: PAPUBKEYS Hash Missing! Processing Flash Image Failed -> Failed to send Certificates Failed to Process all Image files -> Failed to process RM-675_012.004_79.92_prd.core.fpsx here is the problem It needs an Fbus flash BR Alex |
![]() | #49 (permalink) |
Junior Member ![]() ![]() Join Date: Jan 2006 Location: Bulgaria - Germany Age: 45
Member: 224863 Status: Offline Thanks Meter: 9 | try to downgrade version with Nokia C7-00 RM-675_Gr.RUS_sw-012.003.exe I had a problem with C7 Last edited by moulnisky; 12-28-2010 at 02:14. Reason: no names |
![]() | #50 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 24A00206B09C034442647FC545736323FECBA001 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-675_012.004_79.92_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 24A00206B09C034442647FC545736323FECBA001 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_012.004_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Processing Flash Image Failed -> Failed to send Certificates Failed to Process all Image files -> Failed to process RM-675_012.004_79.92_prd.core.fpsx |
![]() | #52 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,055 | Did you tick skip erase? Are you using the TX2 adapter? If you prefer start teamviewer and pass me via PM the connection data.. we can have a look at the mobile together BR Alex |
![]() | #55 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 ![]() | Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Loading secondary boot code: 15168 bytes Secondary boot loaded Loading update server code: 722517 bytes Update server loaded Partitioning.... Partitioning complete Erasing.... Erasing complete Asic CMT: Start programming 1269520 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 40% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 90% Asic CMT: Programming data sent: 100% Programming complete WARNING: Asic CMT: NAND status reported bad blocks Asic CMT: programming succeeded Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 Waiting for communication response: 17 Waiting for communication response: 16 Waiting for communication response: 15 Waiting for communication response: 14 Waiting for communication response: 13 Waiting for communication response: 12 Waiting for communication response: 11 Waiting for communication response: 10 Waiting for communication response: 9 Waiting for communication response: 8 Waiting for communication response: 7 Waiting for communication response: 6 Waiting for communication response: 5 Waiting for communication response: 4 Waiting for communication response: 3 Waiting for communication response: 2 Starting to recover the phone Recoverying phone Initializing Waiting for communication response: 1 Error 0x8401F121 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing Scanning image files... Unable to set the phone to flash mode. Unable to flash. All operations completed Product flashing aborted flashed with phoenix and atf also but phone only vibrate. any idea |
I have 5.28 unlocker by cable. | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 07-13-2000 21:57 |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
