06-30-2009, 14:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: www.GSM10.com
Member: 720059 Status: Offline Thanks Meter: 33 | which cables using to unlock? i tried to unlock nokia 6085 using 7 pin cable....i could not read or unlock...just the phone switching on. thanking all |
06-30-2009, 14:56 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi, If the phone switches itself on means the BSI value in the cable is wrong.. if you have the TMA adapter add the value using the dip switch. If you have not you must modify the cable. remember to use the Yellow adapter (TX2 adapter) when you work with the BB5 mobiles. BR Alex |
06-30-2009, 21:01 | #3 (permalink) |
Member: 720059 Status: Offline Thanks Meter: 33 | which adapter you mean????? how can modified cables? is there spaecial cables fpor BB5? have you any figures or diagrams? iam using now cables normal for JAF , HWK? thanking all |
06-30-2009, 21:12 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | Quote:
did you buy box with cables if you dont then your box came with yellow adapter one that have a male and a female ends, to work with bb5 phones you need to use that adapter and use any 7 pins cable | |
The Following User Says Thank You to denisirias For This Useful Post: |
..: s5233:.. which cable use to unlock????? | shahinahmed007 | UST Pro II | 2 | 02-25-2010 22:04 |
which cable use to unlock lg l1100 | zeeshan tayyab | FuriousGold | 1 | 10-29-2009 13:39 |
which cable use to flash nokia-1208,1650 | Rajan chhetri | HWK | 9 | 08-24-2008 08:13 |
which cable use to flash nokia-6085 its urgent | Rajan chhetri | HWK | 2 | 08-23-2008 14:51 |
Which cable use to flash 3200??? | hoang | UFS2 + UFS3-Tornadoflasher | 1 | 11-27-2003 07:37 |
