06-02-2011, 09:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | Complete guide to the unlock of SL3 mobiles using oclhashcat-lite 1. download and extract to c:\ Download oclHashcat-lite-0.05.7z - hashcat, advanced password recovery 2. download and extract the attached bat file (short-cut to hashcat folder to save time on typing) 3. prepare a command line from readed bruteforce data (refer to attached sample command line and edit with your readed data) ex: oclHashcat-lite64 96F68C3C9EBE65ACEDFC5D57FF2E7C4EFB23F869:003527100497509600 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=352710049750969_COD.txt red line represents sha (40 digit) yellow is your imei (14 digit) violet is your imei (15 digit) light blue (use oclHashcat-lite64 if using 64bit system, use oclHashcat-lite32 if using 32bit system or simply run the bat file readed by cyclone in your hashcat folder and voila!! sample for 32 and 64 bit system below: 4. how to use restore (do not run bat file again or run the command line else lbf will start from 0%) simply use the following restore commands for Windows 7 64 bit ATI AMD Card oclHashcat-lite64 --restore for Windows 7 32 bit ATI AMD Card oclHashcat-lite32 --restore ex. 5. How to skip scan (can be used if restore bin is deleted or corrupted) use only if you are sure of where your lbf job stopped. sample below shows how to start or resume scan at 60% you may edit according to what you want just add --pw-skip=60000000000 oclHashcat-lite64 --pw-skip=60000000000 170EC9542B716B72A3FA195C1F320B53A126A95F:003533820 451534800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=353382045153488.txt ex. good luck! Last edited by Mr.3.; 06-02-2011 at 09:18. |
The Following 10 Users Say Thank You to benguetcowboy1 For This Useful Post: |
06-02-2011, 10:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,132 | How To read HASH , BruteForce , Unlock Via cyclone With Simple screenshot Read HASH Via Cyclone And save it Pick the cmd file related to your card and version of operative system and copy it in the oclhashcat-lite folder Click BAT File After Bruteforce success , Send to server to calculate the code After calculate code successfully, Send via FBUS ALL DONE Always Thanks to my dearest friend ALEX Last edited by moulnisky; 12-14-2011 at 23:21. |
The Following 21 Users Say Thank You to Mr.3. For This Useful Post: |
06-07-2011, 05:11 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | Please give us sample command for start at 60%-100% then go back to 60%-00% or 40%-70% then 100%-70% then 40%-00% is it posibble to make in one command? |
The Following User Says Thank You to Chevka For This Useful Post: |
06-07-2011, 05:37 | #5 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | 60%-100% then back to 0%-50% oclHashcat-lite64 D510319CA27F8207003ED34B13169838F8B8AE16:003593700 373538900 -1 00010203040506070809 -2 06070809000102030405 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 -n 160 --outfile-format=1 --outfile=359370037353897_COD.txt edit with your data and no space between imei Last edited by benguetcowboy1; 06-07-2011 at 05:37. Reason: edit |
The Following 2 Users Say Thank You to benguetcowboy1 For This Useful Post: |
06-25-2011, 23:39 | #8 (permalink) |
Freak Poster Join Date: Jan 2006 Location: colombia
Member: 226132 Status: Offline Thanks Meter: 17 | someone could help me .. I need to comand to various imeis . once you finish one, continue on the other. would be like to create the file. bat? is this is possible .. anybody can helpme . tnks |
07-06-2011, 17:08 | #9 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Slovakia Age: 43
Member: 13922 Status: Offline Thanks Meter: 334 | yes you can create one bat file with several IMEIs (command lines) just put/paste each command line in one 1line so 1st line 1st phone cmd line 2nd line - 2nd phone cmd line |
07-07-2011, 14:48 | #10 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Bosnia and Hercegovina Age: 50
Member: 257050 Status: Offline Thanks Meter: 5 | After oclhashchat LBF cyclone wrong sp codes given. Why? This Calculating NCK Codes for IMEI 351536045639976 from cyclone #pw+322079842368638+1# #pw+070827550722020+2# #pw+078949343172405+3# #pw+499665119829929+4# #pw+982542100848011+5# #pw+753886540701682+6# #pw+877329874175644+7# Finished this good #pw+673223145651861+1# #pw+904878766857834+2# #pw+233538467742495+3# #pw+601868682878995+4# #pw+553395685475267+5# #pw+292279526916251+6# #pw+679179191642446+7# this cyclone codes Calculating NCK Codes for IMEI 354321043819608 #pw+866911653892792+1# #pw+377547194153119+2# #pw+099254818834043+3# #pw+437814030044015+4# #pw+284127616698652+5# #pw+737723789530961+6# #pw+955988979029638+7# Finished this good#pw+705353231388219+1# #pw+550515998495220+2# #pw+887196533199683+3# #pw+205101739469235+4# #pw+817310009961475+5# #pw+200042688790437+6# #pw+065336109548402+7# |
07-08-2011, 06:49 | #11 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
use the cyclone server to receive the level 7 code. Some mobiles don't accept the code level 7 then, only for these mobiles, you can use any other software to generate the code level 1 and input via keyboard. BR Alex | |
07-08-2011, 07:23 | #12 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 229 | Both are good NCK: a6cbc994e04dd22f4e435f73d4314ee754bb1cf6:003569180 369940100:040508040401040109020308010702 Fenix: #pw+551426331521238+7# Cyclone: #pw+648375248714479+7# 100% with both Back locked Then again unlock. |
07-08-2011, 08:48 | #13 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 57
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Alex, Can you help me please with this dubt ? Which .exe need to run for work with ATI 5970 with oclhashcat 0.06 ? And the file .bat as I read with Cyclone is this ? 3579850323xxxxx_ATI_32bit_oclHashCat I use (for the moment) 1x5970 Black Edition 4Gb Win7 32 Thanks and Regards, |
The Following User Says Thank You to Dany For This Useful Post: |
07-08-2011, 09:45 | #14 (permalink) |
Junior Member Join Date: Jan 2008
Member: 686246 Status: Offline Thanks Meter: 0 | I already use 'command line' as above for the bruteforce process, but never succeeded, always appear 'error window': oclHashcat-lite32.exe - Application Error The application failed to initialize properly (0xc0000005 )...... what have I done wrong? or from my computer that are less supportive? |
07-08-2011, 10:18 | #15 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Nadiad Age: 40
Member: 410217 Status: Offline Thanks Meter: 44 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
