Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-02-2011, 09:11   #1 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
Thumbs up Complete guide to the unlock of SL3 mobiles using oclhashcat-lite
simplified instructions below is for ati amd gpu cards using windows7, 32 and 64bit system only other gpu is not included since it takes years to calculate master code...
1. download and extract to c:\ Download oclHashcat-lite-0.05.7z - hashcat, advanced password recovery
2. download and extract the attached bat file (short-cut to hashcat folder to save time on typing)
3. prepare a command line from readed bruteforce data (refer to attached sample command line and edit with your readed data)
ex:
oclHashcat-lite64 96F68C3C9EBE65ACEDFC5D57FF2E7C4EFB23F869:003527100497509600 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=352710049750969_COD.txt
red line represents sha (40 digit)
yellow is your imei (14 digit)
violet is your imei (15 digit)
light blue (use oclHashcat-lite64 if using 64bit system, use oclHashcat-lite32 if using 32bit system
or simply run the bat file readed by cyclone in your hashcat folder and voila!!
sample for 32 and 64 bit system below:
4. how to use restore (do not run bat file again or run the command line else lbf will start from 0%) simply use the following restore commands
for Windows 7 64 bit ATI AMD Card
oclHashcat-lite64 --restore
for Windows 7 32 bit ATI AMD Card
oclHashcat-lite32 --restore
ex.
5. How to skip scan (can be used if restore bin is deleted or corrupted) use only if you are sure of where your lbf job stopped.
sample below shows how to start or resume scan at 60% you may edit according to what you want just add --pw-skip=60000000000
oclHashcat-lite64 --pw-skip=60000000000 170EC9542B716B72A3FA195C1F320B53A126A95F:003533820 451534800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=353382045153488.txt
ex.
good luck!
File Type: rar SL3_LBF.rar (133 Bytes, 7161 views)
File Type: txt sample commandline.txt (760 Bytes, 4217 views)
The Following 10 Users Say Thank You to benguetcowboy1 For This Useful Post:
Old 06-02-2011, 10:29   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
Thumbs up How To read HASH , BruteForce , Unlock Via cyclone
With Simple screenshot
Read HASH Via Cyclone And save it
Pick the cmd file related to your card and version of operative system and copy it in the oclhashcat-lite folder
Click BAT File
After Bruteforce success , Send to server to calculate the code
After calculate code successfully, Send via FBUS
ALL DONE
Always Thanks to my dearest friend ALEX
The Following 21 Users Say Thank You to Mr.3. For This Useful Post:
Old 06-06-2011, 20:29   #3 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
nice info aout sl3 bruteforce
Old 06-07-2011, 05:11   #4 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
Please give us sample command for start at 60%-100% then go back to 60%-00% or
40%-70% then 100%-70% then 40%-00%
is it posibble to make in one command?
The Following User Says Thank You to Chevka For This Useful Post:
Old 06-07-2011, 05:37   #5 (permalink)
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
60%-100% then back to 0%-50%
oclHashcat-lite64 D510319CA27F8207003ED34B13169838F8B8AE16:003593700 373538900 -1 00010203040506070809 -2 06070809000102030405 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 -n 160 --outfile-format=1 --outfile=359370037353897_COD.txt
edit with your data and no space between imei
The Following 2 Users Say Thank You to benguetcowboy1 For This Useful Post:
Old 06-08-2011, 10:04   #6 (permalink)
jam_mobile's Avatar
Member: 649578
Sonork: 100.1592568
Thanks Meter: 70
plz tell me ,how to use in xp ????
Old 06-08-2011, 10:31   #7 (permalink)
Registered User
Member: 1423542
Thanks Meter: 32
It's the same, but on XP only work with one card!
Old 06-25-2011, 23:39   #8 (permalink)
Member: 226132
Thanks Meter: 17
someone could help me .. I need to comand to various imeis . once you finish one, continue on the other. would be like to create the file. bat?
is this is possible .. anybody can helpme . tnks
Old 07-06-2011, 17:08   #9 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
yes you can create one bat file with several IMEIs (command lines)
just put/paste each command line in one 1line
so 1st line 1st phone cmd line
2nd line - 2nd phone cmd line
Old 07-07-2011, 14:48   #10 (permalink)
Member: 257050
Thanks Meter: 5
After oclhashchat LBF cyclone wrong sp codes given. Why?
This Calculating NCK Codes for IMEI 351536045639976 from cyclone
#pw+322079842368638+1#
#pw+070827550722020+2#
#pw+078949343172405+3#
#pw+499665119829929+4#
#pw+982542100848011+5#
#pw+753886540701682+6#
#pw+877329874175644+7#
Finished
this good
#pw+673223145651861+1#
#pw+904878766857834+2#
#pw+233538467742495+3#
#pw+601868682878995+4#
#pw+553395685475267+5#
#pw+292279526916251+6#
#pw+679179191642446+7#
this cyclone codes
Calculating NCK Codes for IMEI 354321043819608
#pw+866911653892792+1#
#pw+377547194153119+2#
#pw+099254818834043+3#
#pw+437814030044015+4#
#pw+284127616698652+5#
#pw+737723789530961+6#
#pw+955988979029638+7#
Finished
this good#pw+705353231388219+1#
#pw+550515998495220+2#
#pw+887196533199683+3#
#pw+205101739469235+4#
#pw+817310009961475+5#
#pw+200042688790437+6#
#pw+065336109548402+7#
Old 07-08-2011, 06:49   #11 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Finished
this good
this cyclone codes
Finished
Cyclone server calculates only the level 7 code so where are coming all the other codes?
use the cyclone server to receive the level 7 code.
Some mobiles don't accept the code level 7 then, only for these mobiles, you can use any other software to generate the code level 1 and input via keyboard.
Alex
Old 07-08-2011, 07:23   #12 (permalink)
Member: 87188
Thanks Meter: 227
Both are good NCK:
a6cbc994e04dd22f4e435f73d4314ee754bb1cf6:003569180 369940100:040508040401040109020308010702
Fenix:
#pw+551426331521238+7#
Cyclone:
#pw+648375248714479+7#
100% with both
Back locked
Then again unlock.
Old 07-08-2011, 08:48   #13 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Alex,
Can you help me please with this dubt ?
Which .exe need to run for work with ATI 5970 with oclhashcat 0.06 ?
And the file .bat as I read with Cyclone is this ?
3579850323xxxxx_ATI_32bit_oclHashCat
I use (for the moment) 1x5970 Black Edition 4Gb
Win7 32
Thanks and Regards,
The Following User Says Thank You to Dany For This Useful Post:
Old 07-08-2011, 09:45   #14 (permalink)
Member: 686246
I already use 'command line' as above for the bruteforce process, but never succeeded, always appear 'error window':
oclHashcat-lite32.exe - Application Error
The application failed to initialize properly (0xc0000005 )......
what have I done wrong?
or from my computer that are less supportive?
Old 07-08-2011, 10:18   #15 (permalink)
Member: 410217
Thanks Meter: 44
Alex
Plz upload all Level Code in cyclone softwere
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.24946 seconds with 10 queries
