08-27-2009, 00:29 | #1 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1105434 Status: Offline Thanks Meter: 0 | I have problem with my cyclone box. Only bootloader mode - No main mode [SOLVED] I used two days perfectly, but now when i try to connect the box, i received this messages: Maintenance: Box Maintenance procedure started at 06:33:44 p.m. Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E Service Tag: 92F386A1632B025FABDEA606E72F15F3 Connecting to Cyclone Server Cyclone Server (1.0.0.478), Cyclone Box Team 2008, 2009 - Ready. ========= Box Info ========= Box SN: C0001928 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: ************* First Name: *********** Surname: ************** Nickname: *********** Address: *********** Country: *********** E-Mail: [email protected] Reseller: Ipmart, Malaysia Warranty Start Date: 2009-08-12 Warranty Period (months): 6 Warranty Stop Date: 2010-02-12 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Disconnected from Cyclone Server Box Maintenance finished successfully Registration: Registration Wizard Ready, Engine Revision: 1.0.0.7880 Box Registration Preparation procedure started at 06:34:07 p.m. Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E Service Tag: 92F386A1632B025FABDEA606E72F15F3 Connecting to Cyclone Server Cyclone Server (1.0.0.478), Cyclone Box Team 2008, 2009 - Ready. Box registration status: Registered OK Box Registration Preparation Error -> Box is already registered! Contact support if any problems occurs. DCT4/WD2/BB5: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7880 Handling device: [Cyclone Team], [Cyclone Bootloader] Initialization has failed -> No connection was established, or box is not in needed mode I Tried in 3 different computers, change the usb cable, and reinstall all software, but received same error..... Could you help me about this ??? |
08-27-2009, 01:04 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | for cyclone box we should install two kind of drivers, bootloader mode driver and normal mode driver maybe u have not installed main mode driver plz remove drivers and install it again |
08-27-2009, 01:04 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Inside ARM...
Member: 457435 Status: Offline Thanks Meter: 24 | this box have 2 drivers..... unistall and reinstal box driver..... plug cyclone whit usb cable....bootloader mode....ok... go to propriets my computer>hardware> and reinstal problem driver..... ******..... |
08-27-2009, 18:54 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Upgrade your box , i have added logs, but i will keep eye on this box ,you should know why |
The Following User Says Thank You to karwos For This Useful Post: |
08-30-2009, 20:57 | #5 (permalink) |
Member: 1105434 Status: Offline Thanks Meter: 0 | Thanks for your help, cyclone. Now the box is working perfectly, but i have some question about this problem. Can i connect the cyclone box in two different computers, or is necesary to use in only one computer ?? Do you have some especific instruccions about how use the box, and avoid some aditional problems ?? Thanks. B.R. |
08-30-2009, 21:02 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You can install it in as many computer you want without problem.. you don't need to register the box again or update again the firmware.. Just install the main suite 1.02, the bulk update 7880 and plug the box BR Alex |
08-30-2009, 21:16 | #7 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ ivanrlovato Quote:
For BB5 use allways the TX2 adapter (the yellow ones) For DCT-4 conect direct to service socket without the TX2 adapter For more info, about unlock procedure, bakups, etc..... read sticky threads... BR | |
The Following User Says Thank You to ptt For This Useful Post: |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
having problem with my twister box | jamesgsm | HWK | 2 | 09-19-2008 19:33 |
im having problem with my new box.. | zulu land | BB5BOX | 3 | 04-27-2008 13:26 |
why remove my post i have problem with my multi box plz help | rajabrotherscom | Multi-Box | 1 | 03-15-2008 17:13 |
i have problem with my furious box | KARIM GSM-ZONE | FuriouS II | 4 | 10-06-2005 14:05 |
