05-04-2009, 19:50 | #1 (permalink) |
Banned Join Date: Apr 2008 Location: new heaven Age: 44
Member: 740265 Status: Offline Thanks Meter: 53 | cyclone destory e51 imei but i cant restore backup Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.03, (May 1 2009 17:13:05, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C00001AC HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D00002CF Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.12v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.84v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Failed to Write PM -> No file assigned by user MCU Version V 100.15.38.2 MCU Date 02-10-07 Product RM-244 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 80 bytes, Status: OK [120,2] Written, Length: 20 bytes, Status: OK [308,1] Written, Length: 8192 bytes, Status: OK Write PM Finished, Record written OK: 4, Record written NOT OK: 0 MCU Version V 100.15.38.2 MCU Date 02-10-07 Product RM-244 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value BB5 Simlock Structure Import Started... MCU Version V 100.15.38.2 MCU Date 02-10-07 Product RM-244 Manufacturer (c) Nokia IMEI 12345610654321? BB5 Simlock Structure Import Failed -> '?' is not a valid integer value Failed to Write RPL File -> No RPL File provided by user Starting PM read in range 0-512... [1] Reading 25 records [1,0] Reading 114 bytes [1,2] Reading 98 bytes [1,4] Reading 110 bytes [1,6] Reading 98 bytes [1,8] Reading 110 bytes [1,13] Reading 98 bytes [1,16] Reading 98 bytes [1,18] Reading 98 bytes [1,20] Reading 98 bytes [1,22] Reading 16 bytes [1,23] Reading 4 bytes [1,24] Reading 84 bytes [1,25] Reading 4 bytes [1,26] Reading 110 bytes [1,28] Reading 98 bytes [1,29] Reading 10 bytes [1,31] Reading 98 bytes [1,33] Reading 36 bytes [1,34] Reading 80 bytes [1,40] Reading 16 bytes [1,41] Reading 182 bytes [1,42] Reading 4 bytes [1,43] Reading 36 bytes [1,44] Reading 182 bytes [1,46] Reading 64 bytes [2] Reading 1 records [2,0] Reading 448 bytes [4] Reading 7 records [4,1] Reading 80 bytes [4,3] Reading 10 bytes [4,4] Reading 8 bytes [4,5] Reading 8 bytes [4,9] Reading 5 bytes [4,26] Reading 132 bytes [4,28] Reading 2 bytes [8] Reading 4 records [8,1] Reading 12 bytes [8,2] Reading 128 bytes [8,3] Reading 128 bytes [8,7] Reading 8 bytes [11] Reading 128 records [11,0] Reading 4 bytes [11,1] Reading 4 bytes [11,2] Reading 4 bytes [11,3] Reading 4 bytes [11,4] Reading 1 bytes [11,5] Reading 6 bytes [11,6] Reading 1 bytes [11,7] Reading 2 bytes [11,8] Reading 2 bytes [11,9] Reading 2 bytes [11,10] Reading 2 bytes [11,11] Reading 2 bytes [11,12] Reading 1 bytes [11,13] Reading 1 bytes [11,14] Reading 1 bytes [11,15] Reading 1 bytes [11,16] Reading 1 bytes [11,17] Reading 1 bytes [11,18] Reading 1 bytes [11,19] Reading 2 bytes [11,20] Reading 2 bytes [11,21] Reading 1 bytes [11,22] Reading 1 bytes [11,23] Reading 4 bytes [11,24] Reading 4 bytes [11,25] Reading 2 bytes [11,26] Reading 2 bytes [11,27] Reading 2 bytes [11,28] Reading 2 bytes [11,29] Reading 1 bytes [11,30] Reading 1 bytes [11,31] Reading 1 bytes [11,32] Reading 1 bytes [11,33] Reading 1 bytes [11,34] Reading 1 bytes [11,35] Reading 1 bytes [11,36] Reading 1 bytes [11,37] Reading 1 bytes [11,38] Reading 2 bytes [11,39] Reading 2 bytes [11,40] Reading 2 bytes [11,41] Reading 2 bytes [11,42] Reading 2 bytes [11,43] Reading 4 bytes [11,44] Reading 4 bytes [11,45] Reading 4 bytes [11,46] Reading 1 bytes [11,47] Reading 16 bytes [11,48] Reading 2 bytes [11,49] Reading 2 bytes [11,50] Reading 20 bytes [11,51] Reading 10 bytes [11,52] Reading 2 bytes [11,53] Reading 20 bytes [11,54] Reading 10 bytes [11,55] Reading 1 bytes [11,56] Reading 1 bytes [11,57] Reading 1 bytes [11,58] Reading 1 bytes [11,59] Reading 1 bytes [11,60] Reading 1 bytes [11,61] Reading 1 bytes [11,62] Reading 1 bytes [11,63] Reading 1 bytes [11,64] Reading 1 bytes [11,65] Reading 1 bytes [11,66] Reading 32 bytes [11,67] Reading 32 bytes [11,68] Reading 2 bytes [11,69] Reading 2 bytes [11,70] Reading 2 bytes [11,71] Reading 2 bytes [11,72] Reading 2 bytes [11,73] Reading 2 bytes [11,74] Reading 2 bytes [11,75] Reading 2 bytes [11,76] Reading 2 bytes [11,77] Reading 2 bytes [11,78] Reading 2 bytes [11,79] Reading 2 bytes [11,80] Reading 2 bytes [11,81] Reading 2 bytes [11,82] Reading 2 bytes [11,83] Reading 2 bytes [11,84] Reading 2 bytes [11,85] Reading 2 bytes [11,86] Reading 2 bytes [11,87] Reading 2 bytes [11,88] Reading 2 bytes [11,89] Reading 2 bytes [11,90] Reading 2 bytes [11,91] Reading 2 bytes [11,92] Reading 2 bytes [11,93] Reading 2 bytes [11,94] Reading 2 bytes [11,95] Reading 2 bytes [11,96] Reading 2 bytes [11,97] Reading 2 bytes [11,98] Reading 2 bytes [11,99] Reading 2 bytes [11,100] Reading 2 bytes [11,101] Reading 2 bytes [11,102] Reading 2 bytes [11,103] Reading 2 bytes [11,104] Reading 2 bytes [11,105] Reading 2 bytes [11,106] Reading 2 bytes [11,107] Reading 2 bytes [11,108] Reading 2 bytes [11,109] Reading 2 bytes [11,110] Reading 2 bytes [11,111] Reading 2 bytes [11,112] Reading 2 bytes [11,113] Reading 2 bytes [11,114] Reading 2 bytes [11,115] Reading 2 bytes [11,116] Reading 4 bytes [11,117] Reading 4 bytes [11,118] Reading 1 bytes [11,119] Reading 4 bytes [11,120] Reading 4 bytes [11,121] Reading 4 bytes [11,122] Reading 4 bytes [11,123] Reading 16 bytes [11,124] Reading 4 bytes [11,125] Reading 2 bytes [11,126] Reading 2 bytes [11,127] Reading 1435 bytes [12] Reading 1 records [12,0] Reading 102 bytes [31] Reading 1 records [31,4] Reading 18 bytes [44] Reading 1 records [44,0] Reading 1 bytes [50] Reading 1 records [50,0] Reading 2 bytes [54] Reading 2 records [54,0] Reading 2 bytes [54,2] Reading 24 bytes [88] Reading 1 records [88,0] Reading 36 bytes [96] Reading 1 records [96,0] Reading 24 bytes [107] Reading 6 records [107,0] Reading 21 bytes [107,1] Reading 79 bytes [107,2] Reading 79 bytes [107,3] Reading 70 bytes [107,25] Reading 132 bytes [107,26] Reading 12 bytes [117] Reading 11 records [117,0] Reading 4 bytes [117,1] Reading 3 bytes [117,2] Reading 6 bytes [117,3] Reading 1 bytes [117,4] Reading 9 bytes [117,5] Reading 10 bytes [117,6] Reading 8 bytes [117,8] Reading 42 bytes [117,13] Reading 3 bytes [117,14] Reading 3 bytes [117,16] Reading 40 bytes [120] Reading 4 records [120,0] Reading 56 bytes [120,1] Reading 80 bytes [120,2] Reading 20 bytes [120,3] Reading 112 bytes [193] Reading 4 records [193,2] Reading 8 bytes [193,3] Reading 32 bytes [193,4] Reading 32 bytes [193,9] Reading 64 bytes [208] Reading 1 records [208,1] Reading 4 bytes [217] Reading 1 records [217,0] Reading 32 bytes [308] Reading 9 records [308,0] Reading 1 bytes [308,1] Reading 8192 bytes [308,3] Reading 1 bytes [308,4] Reading 1 bytes [308,5] Reading 10 bytes [308,6] Reading 1 bytes [308,7] Reading 1 bytes [308,8] Reading 1 bytes [308,9] Reading 40 bytes [309] Reading 9 records [309,0] Reading 4 bytes [309,1] Reading 2 bytes [309,2] Reading 12 bytes [309,4] Reading 12 bytes [309,5] Reading 12 bytes [309,7] Reading 12 bytes [309,8] Reading 12 bytes [309,17] Reading 12 bytes [309,22] Reading 12 bytes [313] Reading 1 records [313,0] Reading 615 bytes [322] Reading 1 records [322,0] Reading 1 bytes [334] Reading 1 records [334,0] Reading 1 bytes [354] Reading 1 records [354,0] Reading 13 bytes [356] Reading 2 records [356,0] Reading 2 bytes [356,1] Reading 8 bytes PM Read OK, Time taken 18.250s [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: OK [1,18] Written, Length: 98 bytes, Status: OK [1,20] Written, Length: 98 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 182 bytes, Status: OK [1,46] Written, Length: 64 bytes, Status: OK [2,0] Written, Length: 448 bytes, Status: OK [4,1] Written, Length: 80 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 12 bytes, Status: OK [8,2] Written, Length: 128 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,7] Written, Length: 8 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 1 bytes, Status: OK [11,7] Written, Length: 2 bytes, Status: OK [11,8] Written, Length: 2 bytes, Status: OK [11,9] Written, Length: 2 bytes, Status: OK [11,10] Written, Length: 2 bytes, Status: OK [11,11] Written, Length: 2 bytes, Status: OK [11,12] Written, Length: 1 bytes, Status: OK [11,13] Written, Length: 1 bytes, Status: OK [11,14] Written, Length: 1 bytes, Status: OK [11,15] Written, Length: 1 bytes, Status: OK [11,16] Written, Length: 1 bytes, Status: OK [11,17] Written, Length: 1 bytes, Status: OK [11,18] Written, Length: 1 bytes, Status: OK [11,19] Written, Length: 2 bytes, Status: OK [11,20] Written, Length: 2 bytes, Status: OK [11,21] Written, Length: 1 bytes, Status: OK [11,22] Written, Length: 1 bytes, Status: OK [11,23] Written, Length: 4 bytes, Status: OK [11,24] Written, Length: 4 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 1 bytes, Status: OK [11,30] Written, Length: 1 bytes, Status: OK [11,31] Written, Length: 1 bytes, Status: OK [11,32] Written, Length: 1 bytes, Status: OK [11,33] Written, Length: 1 bytes, Status: OK [11,34] Written, Length: 1 bytes, Status: OK [11,35] Written, Length: 1 bytes, Status: OK [11,36] Written, Length: 1 bytes, Status: OK [11,37] Written, Length: 1 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 4 bytes, Status: OK [11,44] Written, Length: 4 bytes, Status: OK [11,45] Written, Length: 4 bytes, Status: OK [11,46] Written, Length: 1 bytes, Status: OK [11,47] Written, Length: 16 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 20 bytes, Status: OK [11,51] Written, Length: 10 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 20 bytes, Status: OK [11,54] Written, Length: 10 bytes, Status: OK [11,55] Written, Length: 1 bytes, Status: OK [11,56] Written, Length: 1 bytes, Status: OK [11,57] Written, Length: 1 bytes, Status: OK [11,58] Written, Length: 1 bytes, Status: OK [11,59] Written, Length: 1 bytes, Status: OK [11,60] Written, Length: 1 bytes, Status: OK [11,61] Written, Length: 1 bytes, Status: OK [11,62] Written, Length: 1 bytes, Status: OK [11,63] Written, Length: 1 bytes, Status: OK [11,64] Written, Length: 1 bytes, Status: OK [11,65] Written, Length: 1 bytes, Status: OK [11,66] Written, Length: 32 bytes, Status: OK [11,67] Written, Length: 32 bytes, Status: OK [11,68] Written, Length: 2 bytes, Status: OK [11,69] Written, Length: 2 bytes, Status: OK [11,70] Written, Length: 2 bytes, Status: OK [11,71] Written, Length: 2 bytes, Status: OK [11,72] Written, Length: 2 bytes, Status: OK [11,73] Written, Length: 2 bytes, Status: OK [11,74] Written, Length: 2 bytes, Status: OK [11,75] Written, Length: 2 bytes, Status: OK [11,76] Written, Length: 2 bytes, Status: OK [11,77] Written, Length: 2 bytes, Status: OK [11,78] Written, Length: 2 bytes, Status: OK [11,79] Written, Length: 2 bytes, Status: OK [11,80] Written, Length: 2 bytes, Status: OK [11,81] Written, Length: 2 bytes, Status: OK [11,82] Written, Length: 2 bytes, Status: OK [11,83] Written, Length: 2 bytes, Status: OK [11,84] Written, Length: 2 bytes, Status: OK [11,85] Written, Length: 2 bytes, Status: OK [11,86] Written, Length: 2 bytes, Status: OK [11,87] Written, Length: 2 bytes, Status: OK [11,88] Written, Length: 2 bytes, Status: OK [11,89] Written, Length: 2 bytes, Status: OK [11,90] Written, Length: 2 bytes, Status: OK [11,91] Written, Length: 2 bytes, Status: OK [11,92] Written, Length: 2 bytes, Status: OK [11,93] Written, Length: 2 bytes, Status: OK [11,94] Written, Length: 2 bytes, Status: OK [11,95] Written, Length: 2 bytes, Status: OK [11,96] Written, Length: 2 bytes, Status: OK [11,97] Written, Length: 2 bytes, Status: OK [11,98] Written, Length: 2 bytes, Status: OK [11,99] Written, Length: 2 bytes, Status: OK [11,100] Written, Length: 2 bytes, Status: OK [11,101] Written, Length: 2 bytes, Status: OK [11,102] Written, Length: 2 bytes, Status: OK [11,103] Written, Length: 2 bytes, Status: OK [11,104] Written, Length: 2 bytes, Status: OK [11,105] Written, Length: 2 bytes, Status: OK [11,106] Written, Length: 2 bytes, Status: OK [11,107] Written, Length: 2 bytes, Status: OK [11,108] Written, Length: 2 bytes, Status: OK [11,109] Written, Length: 2 bytes, Status: OK [11,110] Written, Length: 2 bytes, Status: OK [11,111] Written, Length: 2 bytes, Status: OK [11,112] Written, Length: 2 bytes, Status: OK [11,113] Written, Length: 2 bytes, Status: OK [11,114] Written, Length: 2 bytes, Status: OK [11,115] Written, Length: 2 bytes, Status: OK [11,116] Written, Length: 4 bytes, Status: OK [11,117] Written, Length: 4 bytes, Status: OK [11,118] Written, Length: 1 bytes, Status: OK [11,119] Written, Length: 4 bytes, Status: OK [11,120] Written, Length: 4 bytes, Status: OK [11,121] Written, Length: 4 bytes, Status: OK [11,122] Written, Length: 4 bytes, Status: OK [11,123] Written, Length: 16 bytes, Status: OK [11,124] Written, Length: 4 bytes, Status: OK [11,125] Written, Length: 2 bytes, Status: OK [11,126] Written, Length: 2 bytes, Status: OK [11,127] Written, Length: 1435 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [31,4] Written, Length: 18 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 24 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,4] Written, Length: 9 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 80 bytes, Status: OK [120,2] Written, Length: 20 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: OK [308,1] Written, Length: 8192 bytes, Status: OK [308,3] Written, Length: 1 bytes, Status: OK [308,4] Written, Length: 1 bytes, Status: OK [308,5] Written, Length: 10 bytes, Status: OK [308,6] Written, Length: 1 bytes, Status: OK [308,7] Written, Length: 1 bytes, Status: OK [308,8] Written, Length: 1 bytes, Status: OK [308,9] Written, Length: 40 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK [313,0] Written, Length: 615 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [354,0] Written, Length: 13 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK Write PM Finished, Record written OK: 224, Record written NOT OK: 0 MCU Version V 100.15.38.2 MCU Date 02-10-07 Product RM-244 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value Starting PM read in range 0-512... [1] Reading 25 records [1,0] Reading 114 bytes [1,2] Reading 98 bytes [1,4] Reading 110 bytes [1,6] Reading 98 bytes [1,8] Reading 110 bytes [1,13] Reading 98 bytes [1,16] Reading 98 bytes [1,18] Reading 98 bytes [1,20] Reading 98 bytes [1,22] Reading 16 bytes [1,23] Reading 4 bytes [1,24] Reading 84 bytes [1,25] Reading 4 bytes [1,26] Reading 110 bytes [1,28] Reading 98 bytes [1,29] Reading 10 bytes [1,31] Reading 98 bytes [1,33] Reading 36 bytes [1,34] Reading 80 bytes [1,40] Reading 16 bytes [1,41] Reading 182 bytes [1,42] Reading 4 bytes [1,43] Reading 36 bytes [1,44] Reading 182 bytes [1,46] Reading 64 bytes [2] Reading 1 records [2,0] Reading 448 bytes [4] Reading 7 records [4,1] Reading 80 bytes [4,3] Reading 10 bytes [4,4] Reading 8 bytes [4,5] Reading 8 bytes [4,9] Reading 5 bytes [4,26] Reading 132 bytes [4,28] Reading 2 bytes [8] Reading 4 records [8,1] Reading 12 bytes [8,2] Reading 128 bytes [8,3] Reading 128 bytes [8,7] Reading 8 bytes [11] Reading 128 records [11,0] Reading 4 bytes [11,1] Reading 4 bytes [11,2] Reading 4 bytes [11,3] Reading 4 bytes [11,4] Reading 1 bytes [11,5] Reading 6 bytes [11,6] Reading 1 bytes [11,7] Reading 2 bytes [11,8] Reading 2 bytes [11,9] Reading 2 bytes [11,10] Reading 2 bytes [11,11] Reading 2 bytes [11,12] Reading 1 bytes [11,13] Reading 1 bytes [11,14] Reading 1 bytes [11,15] Reading 1 bytes [11,16] Reading 1 bytes [11,17] Reading 1 bytes [11,18] Reading 1 bytes [11,19] Reading 2 bytes [11,20] Reading 2 bytes [11,21] Reading 1 bytes [11,22] Reading 1 bytes [11,23] Reading 4 bytes [11,24] Reading 4 bytes [11,25] Reading 2 bytes [11,26] Reading 2 bytes [11,27] Reading 2 bytes [11,28] Reading 2 bytes [11,29] Reading 1 bytes [11,30] Reading 1 bytes [11,31] Reading 1 bytes [11,32] Reading 1 bytes [11,33] Reading 1 bytes [11,34] Reading 1 bytes [11,35] Reading 1 bytes [11,36] Reading 1 bytes [11,37] Reading 1 bytes [11,38] Reading 2 bytes [11,39] Reading 2 bytes [11,40] Reading 2 bytes [11,41] Reading 2 bytes [11,42] Reading 2 bytes [11,43] Reading 4 bytes [11,44] Reading 4 bytes [11,45] Reading 4 bytes [11,46] Reading 1 bytes [11,47] Reading 16 bytes [11,48] Reading 2 bytes [11,49] Reading 2 bytes [11,50] Reading 20 bytes [11,51] Reading 10 bytes [11,52] Reading 2 bytes [11,53] Reading 20 bytes [11,54] Reading 10 bytes [11,55] Reading 1 bytes [11,56] Reading 1 bytes [11,57] Reading 1 bytes [11,58] Reading 1 bytes [11,59] Reading 1 bytes [11,60] Reading 1 bytes [11,61] Reading 1 bytes [11,62] Reading 1 bytes [11,63] Reading 1 bytes [11,64] Reading 1 bytes [11,65] Reading 1 bytes [11,66] Reading 32 bytes [11,67] Reading 32 bytes [11,68] Reading 2 bytes [11,69] Reading 2 bytes [11,70] Reading 2 bytes [11,71] Reading 2 bytes [11,72] Reading 2 bytes [11,73] Reading 2 bytes [11,74] Reading 2 bytes [11,75] Reading 2 bytes [11,76] Reading 2 bytes [11,77] Reading 2 bytes [11,78] Reading 2 bytes [11,79] Reading 2 bytes [11,80] Reading 2 bytes [11,81] Reading 2 bytes [11,82] Reading 2 bytes [11,83] Reading 2 bytes [11,84] Reading 2 bytes [11,85] Reading 2 bytes [11,86] Reading 2 bytes [11,87] Reading 2 bytes [11,88] Reading 2 bytes [11,89] Reading 2 bytes [11,90] Reading 2 bytes [11,91] Reading 2 bytes [11,92] Reading 2 bytes [11,93] Reading 2 bytes [11,94] Reading 2 bytes [11,95] Reading 2 bytes [11,96] Reading 2 bytes [11,97] Reading 2 bytes [11,98] Reading 2 bytes [11,99] Reading 2 bytes [11,100] Reading 2 bytes [11,101] Reading 2 bytes [11,102] Reading 2 bytes [11,103] Reading 2 bytes [11,104] Reading 2 bytes [11,105] Reading 2 bytes [11,106] Reading 2 bytes [11,107] Reading 2 bytes [11,108] Reading 2 bytes [11,109] Reading 2 bytes [11,110] Reading 2 bytes [11,111] Reading 2 bytes [11,112] Reading 2 bytes [11,113] Reading 2 bytes [11,114] Reading 2 bytes [11,115] Reading 2 bytes [11,116] Reading 4 bytes [11,117] Reading 4 bytes [11,118] Reading 1 bytes [11,119] Reading 4 bytes [11,120] Reading 4 bytes [11,121] Reading 4 bytes [11,122] Reading 4 bytes [11,123] Reading 16 bytes [11,124] Reading 4 bytes [11,125] Reading 2 bytes [11,126] Reading 2 bytes [11,127] Reading 1435 bytes [12] Reading 1 records [12,0] Reading 102 bytes [31] Reading 1 records [31,4] Reading 18 bytes [44] Reading 1 records [44,0] Reading 1 bytes [50] Reading 1 records [50,0] Reading 2 bytes [54] Reading 2 records [54,0] Reading 2 bytes [54,2] Reading 24 bytes [88] Reading 1 records [88,0] Reading 36 bytes [96] Reading 1 records [96,0] Reading 24 bytes [107] Reading 6 records [107,0] Reading 21 bytes [107,1] Reading 79 bytes [107,2] Reading 79 bytes [107,3] Reading 70 bytes [107,25] Reading 132 bytes [107,26] Reading 12 bytes [117] Reading 11 records [117,0] Reading 4 bytes [117,1] Reading 3 bytes [117,2] Reading 6 bytes [117,3] Reading 1 bytes [117,4] Reading 9 bytes [117,5] Reading 10 bytes [117,6] Reading 8 bytes [117,8] Reading 42 bytes [117,13] Reading 3 bytes [117,14] Reading 3 bytes [117,16] Reading 40 bytes [120] Reading 4 records [120,0] Reading 56 bytes [120,1] Reading 80 bytes [120,2] Reading 20 bytes [120,3] Reading 112 bytes [193] Reading 4 records [193,2] Reading 8 bytes [193,3] Reading 32 bytes [193,4] Reading 32 bytes [193,9] Reading 64 bytes [208] Reading 1 records [208,1] Reading 4 bytes [217] Reading 1 records [217,0] Reading 32 bytes [308] Reading 9 records [308,0] Reading 1 bytes [308,1] Reading 8192 bytes [308,3] Reading 1 bytes [308,4] Reading 1 bytes [308,5] Reading 10 bytes [308,6] Reading 1 bytes [308,7] Reading 1 bytes [308,8] Reading 1 bytes [308,9] Reading 40 bytes [309] Reading 9 records [309,0] Reading 4 bytes [309,1] Reading 2 bytes [309,2] Reading 12 bytes [309,4] Reading 12 bytes [309,5] Reading 12 bytes [309,7] Reading 12 bytes [309,8] Reading 12 bytes [309,17] Reading 12 bytes [309,22] Reading 12 bytes [313] Reading 1 records [313,0] Reading 615 bytes [322] Reading 1 records [322,0] Reading 1 bytes [334] Reading 1 records [334,0] Reading 1 bytes [354] Reading 1 records [354,0] Reading 13 bytes [356] Reading 2 records [356,0] Reading 2 bytes [356,1] Reading 8 bytes PM Read OK, Time taken 18.235s [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: OK [1,18] Written, Length: 98 bytes, Status: OK [1,20] Written, Length: 98 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 182 bytes, Status: OK [1,46] Written, Length: 64 bytes, Status: OK [2,0] Written, Length: 448 bytes, Status: OK [4,1] Written, Length: 80 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 12 bytes, Status: OK [8,2] Written, Length: 128 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,7] Written, Length: 8 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 1 bytes, Status: OK [11,7] Written, Length: 2 bytes, Status: OK [11,8] Written, Length: 2 bytes, Status: OK [11,9] Written, Length: 2 bytes, Status: OK [11,10] Written, Length: 2 bytes, Status: OK [11,11] Written, Length: 2 bytes, Status: OK [11,12] Written, Length: 1 bytes, Status: OK [11,13] Written, Length: 1 bytes, Status: OK [11,14] Written, Length: 1 bytes, Status: OK [11,15] Written, Length: 1 bytes, Status: OK [11,16] Written, Length: 1 bytes, Status: OK [11,17] Written, Length: 1 bytes, Status: OK [11,18] Written, Length: 1 bytes, Status: OK [11,19] Written, Length: 2 bytes, Status: OK [11,20] Written, Length: 2 bytes, Status: OK [11,21] Written, Length: 1 bytes, Status: OK [11,22] Written, Length: 1 bytes, Status: OK [11,23] Written, Length: 4 bytes, Status: OK [11,24] Written, Length: 4 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 1 bytes, Status: OK [11,30] Written, Length: 1 bytes, Status: OK [11,31] Written, Length: 1 bytes, Status: OK [11,32] Written, Length: 1 bytes, Status: OK [11,33] Written, Length: 1 bytes, Status: OK [11,34] Written, Length: 1 bytes, Status: OK [11,35] Written, Length: 1 bytes, Status: OK [11,36] Written, Length: 1 bytes, Status: OK [11,37] Written, Length: 1 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 4 bytes, Status: OK [11,44] Written, Length: 4 bytes, Status: OK [11,45] Written, Length: 4 bytes, Status: OK [11,46] Written, Length: 1 bytes, Status: OK [11,47] Written, Length: 16 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 20 bytes, Status: OK [11,51] Written, Length: 10 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 20 bytes, Status: OK [11,54] Written, Length: 10 bytes, Status: OK [11,55] Written, Length: 1 bytes, Status: OK [11,56] Written, Length: 1 bytes, Status: OK [11,57] Written, Length: 1 bytes, Status: OK [11,58] Written, Length: 1 bytes, Status: OK [11,59] Written, Length: 1 bytes, Status: OK [11,60] Written, Length: 1 bytes, Status: OK [11,61] Written, Length: 1 bytes, Status: OK [11,62] Written, Length: 1 bytes, Status: OK [11,63] Written, Length: 1 bytes, Status: OK [11,64] Written, Length: 1 bytes, Status: OK [11,65] Written, Length: 1 bytes, Status: OK [11,66] Written, Length: 32 bytes, Status: OK [11,67] Written, Length: 32 bytes, Status: OK [11,68] Written, Length: 2 bytes, Status: OK [11,69] Written, Length: 2 bytes, Status: OK [11,70] Written, Length: 2 bytes, Status: OK [11,71] Written, Length: 2 bytes, Status: OK [11,72] Written, Length: 2 bytes, Status: OK [11,73] Written, Length: 2 bytes, Status: OK [11,74] Written, Length: 2 bytes, Status: OK [11,75] Written, Length: 2 bytes, Status: OK [11,76] Written, Length: 2 bytes, Status: OK [11,77] Written, Length: 2 bytes, Status: OK [11,78] Written, Length: 2 bytes, Status: OK [11,79] Written, Length: 2 bytes, Status: OK [11,80] Written, Length: 2 bytes, Status: OK [11,81] Written, Length: 2 bytes, Status: OK [11,82] Written, Length: 2 bytes, Status: OK [11,83] Written, Length: 2 bytes, Status: OK [11,84] Written, Length: 2 bytes, Status: OK [11,85] Written, Length: 2 bytes, Status: OK [11,86] Written, Length: 2 bytes, Status: OK [11,87] Written, Length: 2 bytes, Status: OK [11,88] Written, Length: 2 bytes, Status: OK [11,89] Written, Length: 2 bytes, Status: OK [11,90] Written, Length: 2 bytes, Status: OK [11,91] Written, Length: 2 bytes, Status: OK [11,92] Written, Length: 2 bytes, Status: OK [11,93] Written, Length: 2 bytes, Status: OK [11,94] Written, Length: 2 bytes, Status: OK [11,95] Written, Length: 2 bytes, Status: OK [11,96] Written, Length: 2 bytes, Status: OK [11,97] Written, Length: 2 bytes, Status: OK [11,98] Written, Length: 2 bytes, Status: OK [11,99] Written, Length: 2 bytes, Status: OK [11,100] Written, Length: 2 bytes, Status: OK [11,101] Written, Length: 2 bytes, Status: OK [11,102] Written, Length: 2 bytes, Status: OK [11,103] Written, Length: 2 bytes, Status: OK [11,104] Written, Length: 2 bytes, Status: OK [11,105] Written, Length: 2 bytes, Status: OK [11,106] Written, Length: 2 bytes, Status: OK [11,107] Written, Length: 2 bytes, Status: OK [11,108] Written, Length: 2 bytes, Status: OK [11,109] Written, Length: 2 bytes, Status: OK [11,110] Written, Length: 2 bytes, Status: OK [11,111] Written, Length: 2 bytes, Status: OK [11,112] Written, Length: 2 bytes, Status: OK [11,113] Written, Length: 2 bytes, Status: OK [11,114] Written, Length: 2 bytes, Status: OK [11,115] Written, Length: 2 bytes, Status: OK [11,116] Written, Length: 4 bytes, Status: OK [11,117] Written, Length: 4 bytes, Status: OK [11,118] Written, Length: 1 bytes, Status: OK [11,119] Written, Length: 4 bytes, Status: OK [11,120] Written, Length: 4 bytes, Status: OK [11,121] Written, Length: 4 bytes, Status: OK [11,122] Written, Length: 4 bytes, Status: OK [11,123] Written, Length: 16 bytes, Status: OK [11,124] Written, Length: 4 bytes, Status: OK [11,125] Written, Length: 2 bytes, Status: OK [11,126] Written, Length: 2 bytes, Status: OK [11,127] Written, Length: 1435 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [31,4] Written, Length: 18 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 24 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,4] Written, Length: 9 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 80 bytes, Status: OK [120,2] Written, Length: 20 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: OK [308,1] Written, Length: 8192 bytes, Status: OK [308,3] Written, Length: 1 bytes, Status: OK [308,4] Written, Length: 1 bytes, Status: OK [308,5] Written, Length: 10 bytes, Status: OK [308,6] Written, Length: 1 bytes, Status: OK [308,7] Written, Length: 1 bytes, Status: OK [308,8] Written, Length: 1 bytes, Status: OK [308,9] Written, Length: 40 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK [313,0] Written, Length: 615 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [354,0] Written, Length: 13 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK Write PM Finished, Record written OK: 224, Record written NOT OK: 0 what should i do to restore backup? and phone also hang nokia on phone screen. |
05-04-2009, 20:42 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | 1st - before unlock - ATTACH TX2 ADAPTER !! ITS NEEDED TO REWRITE NPC BACKUP 2nd - if you already not attached your adapter - attach it - click WRITE CERT and write backup which is made automatically before unlock begins |
6263 restore backup certs not done need cyclone team help | Sudan-Mobiles | Cyclonebox | 7 | 01-13-2010 11:30 |
N85 cant restore backup | badillo | Nokia Base Band 5 ( BB-5 ) | 4 | 01-11-2010 19:36 |
i have full back up but i cant restore | BARAN-MOBILE | Nokia Base Band 5 ( BB-5 ) | 9 | 09-17-2009 09:47 |
Cant restore backup ??? - >> problem solved << | M_ALEX | NoooX Box | 7 | 08-31-2008 10:37 |
3310 4.19 cant restore backup | djmattamondo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-15-2001 17:54 |
