Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-06-2013, 21:19   #1 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Angry Cyclone NO TP - USB ONLY Rooting for Lumia 800, 800C Released ;)
Hi everyone
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-801 LUMIA 800
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-802 LUMIA 800C
All NOKIA DLOAD OSBL loaders are supported (even latest one!)
Instructions:
1. Run Cyclone, it will be auto-updated
2. Update your Box Firmware to v2.20
3. Go to WP7 -> Simlocks Tab
4. Select Product and click ROOT!
It should go this way:
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[Urządzenie kompozytowe USB]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
Switching to RAW Mode...
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Timestamp: 2012-02-17 14:40:05
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic: WP70
Version: 0
Signer Server ID: 0x98031573
Signer Timestamp: 2011-09-28 15:52:12
Signer S/N: 23
Signer User ID: 10046114
Auth Level: Care
Data Encryption: 0
Image Index: 0
Asic Index: 0
Type: Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 0.358s (Average speed: 19462,61kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting MCU...
Rooting Finished!
After rooting, Qualcomm Bootloader is installed. That means phone will be detected as Mass Storage Device, and you will have full access to eMMC.
Because patching is not good solution, we will add some good news aswell in next days
However, if you need simlock patching badly you can use some free tools around to patch AMSS (i.e. NSS).
Release Notes:
1. Supported products: Cyclone Box Classic, Cyclone Box Reloaded, Cyclone Key
2. Firmware Required v2.20
3. Need No TP Activation, is COMPLETLY FREE for all Cyclone Key users, for rest you need have 60 credits on your account and your box will be automatically activated (credits will not be withdrawn from box anyway, this is just threshold).
4. We also have solution to completly root rest of lumias, including 610, 610nfc, 900, etc... however it will be released ONLY if this solution WILL NOT BE COPIED. If somebody copy solution - it will be kept private.
5. No need new installer, however if you need one, always latest one is here: http://www.**********/CycloneBoxInstaller.exe
Best Regards,
Cyclone Team
The Following 41 Users Say Thank You to karwos For This Useful Post:
Old 08-06-2013, 21:29   #2 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 760
Cyclone team....now flying.........waiting....more.........
The Following User Says Thank You to .::Gsm-Play::. For This Useful Post:
Old 08-06-2013, 21:37   #3 (permalink)
Member: 217891
Thanks Meter: 237
i can can unlock lumia now ???
Old 08-06-2013, 21:39   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Just root your phone and patch it by NSS for example ...
if you don't like patching, as I do, wait and we will present permanent unlock.
The Following 10 Users Say Thank You to karwos For This Useful Post:
Old 08-06-2013, 21:43   #5 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
IS there Any chance of Damage of emmc During Root??....
Old 08-06-2013, 21:43   #6 (permalink)
Member: 217891
Thanks Meter: 237
i not understand u ? now if i do this root my phone unlock network ?
Old 08-06-2013, 21:52   #7 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Rooting procedure is SAFE. However, after rooting new MMC device will be detected, and Windows will ask you to format it. If you click yes, MMC will be erased. Don't do it, and you're safe.
The Following User Says Thank You to karwos For This Useful Post:
Old 08-06-2013, 22:01   #8 (permalink)
Registered User
Member: 246072
Thanks Meter: 96
nice update, waiting for others lumia´s to activate my cyclone reload edition
Old 08-06-2013, 22:57   #9 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
why not Activated please cleared
ox Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number:xxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: Dxxxxxxx
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.00v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.80v PASSED
VBAT Voltage 0.00v PASSED
VBAT Voltage 4.96v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.88v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is NOT ACTIVATED! (1)
Old 08-06-2013, 23:09   #10 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Card is activated
Box is activated
USB Voltage5.00vPASSED
MCU Voltage3.27vPASSED
Core Voltage1.80vPASSED
VBAT Voltage0.00vPASSED
VBAT Voltage4.96vPASSED
Box VPP disabled
VPP Voltage0.04vPASSED
VPP Voltage4.88vPASSED
Box VPP disabled
VPP Voltage0.02vPASSED
VPP Voltage0.00vFAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Check your credit count in server tools tab. Once refilled to 60, update your box again.
Old 08-06-2013, 23:10   #11 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
Please paste Your SN to check Your credit amount- this service is for FREE to Cyclone Key edition, but when You have Classic or Reloaded You need have on account 60 credits for activate Lumia No TP.
Old 08-06-2013, 23:11   #12 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
Best Regards,
Cyclone Team
i have 59 Credits left.
any consideration to ACTIVATE it
Box Serial Number: C00020C7
Card Serial Number: D8000316
br
[ R ] [ N ] [ C ] [ _ ] [ E ] [ B ] [ M ]
[ iPhone5-7.0 Beta 5 - FU / iPhone4s-6.1.3 - FU ]
Old 08-06-2013, 23:17   #13 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
Box Serial Number: C0000138
Card Serial Number: XXXXXX
Sir i want to with draw from my" XPERIA ACCOUNT " PLEASE ANY POSSIBILITY
Old 08-06-2013, 23:18   #14 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
br
Send me your box serial, i will activate it as a gift
And post your successfull root stories
The Following 2 Users Say Thank You to karwos For This Useful Post:
Old 08-06-2013, 23:20   #15 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
THANK YOU VERY MUCH.
br
Page generated in 2.49150 seconds with 8 queries
