02-13-2010, 16:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: BIH,Bratunac
Member: 888715 Status: Offline Thanks Meter: 109 | Cyclonebox problem help [SOLVED] http://rapidshare.com/files/35011448...html:confused: |
02-13-2010, 17:21 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | ok.. using notepad open the file is shown in the error window (It is in the folder c:\program files\cyclone box\) copy the ocntent of this file and send them to siroya via PM He will solve your issue on the server BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
02-13-2010, 17:41 | #6 (permalink) |
Member: 888715 Status: Offline Thanks Meter: 109 | Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: xxxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number:xxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,93v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,75v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Behold now works thanks |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
1650 problem,help[SOLVED] | sebY7676 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-24-2010 22:04 |
help me cyclonebox not work [ Solved ] | sfeansfean | Cyclonebox | 3 | 01-11-2010 19:49 |
Cyclonebox teams help | vaghubha_sodha | Cyclonebox | 34 | 11-05-2009 05:27 |
dear cyclonebox please help me.. | kemakaza | Cyclonebox | 8 | 08-07-2009 07:26 |
