07-11-2009, 10:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: China/USA
Member: 718425 Status: Offline Thanks Meter: 5,873 | Cyclonebox SX4 Not work Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.03, (May 1 2009 17:13:05, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0000218 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000*** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.94v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.44v PASSED VBAT Voltage 4.72v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.04v is out of valid range Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1C100211D1417B5648341D380D3BE07C9B6B45D8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0020881C00006A21, ST, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Subsystem Not Found Restarting MCU... SX4 Status: Not authorized (76) Started mutual authenthication with card... Cyclone Server (1.0.0.476), Cyclone Box Team 2008, 2009 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Disconnected from Cyclone Server Failed to Authorize SX4 -> Failed to receive mutual Data 2 from server |
07-11-2009, 17:07 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Mediteranean
Member: 59352 Status: Offline Thanks Meter: 50 | CU Version V 06wk41v51.3 MCU Date 13-02-08 Product RM-320 Manufacturer (c) Nokia IMEI 356842022761485 Mastercode 4453223060 IMEI Spare 3A65480222674108 IMEI SV 3365480222674108F4000000 PSN M2O102411 Product Code 0558166 Basic Product Code 0548236 PSD 0000000000000000 LPSN 0 WLAN MAC 0022FD4B2161 RETU 15 TAHVO 22 AHNE 11 HW 4251 RFIC 17141715 DSP mc_3131_ICPR62_2008w04 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 64710F BB5 Unlock Started... MCU Version V 06wk41v51.3 MCU Date 13-02-08 Product RM-320 Manufacturer (c) Nokia IMEI 356842022761485 Mastercode 4453223060 Warning: Failed to read SP Info, Assuming defaults Simlock Server Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... BB5 Unlock Failed -> Failed to read PM 308, this is critical SX4 Status: Not authorized (76) Started mutual authenthication with card... Cyclone Server (1.0.0.476), Cyclone Box Team 2008, 2009 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Disconnected from Cyclone Server Failed to Authorize SX4 -> Failed to receive mutual Data 2 from server |
07-14-2009, 08:19 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | plz nelp me cyclone team for my n70 it getting off every 30 min(power ic changed) Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C000xxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D00xxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.10v PASSED VBAT Voltage 4.95v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work SX4 Status: Not authorized (76) Started mutual authenthication with card... Cyclone Server (1.0.0.476), Cyclone Box Team 2008, 2009 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Disconnected from Cyclone Server Failed to Authorize SX4 -> Failed to receive mutual Data 2 from server |
07-14-2009, 15:31 | #7 (permalink) |
Member: 170684 Status: Offline Thanks Meter: 19 | Selftests to proceed: 34 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Failed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Failed ST_CDSP_RF_BB_IF_TEST Failed ST_CDSP_RF_SUPPLY_TEST Failed ST_CDSP_TX_IQ_TEST Failed ST_CDSP_TXC_DATA_TEST Failed ST_CDSP_WCDMA_TX_POWER_TEST Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BT_SLEEP_CLK_TEST Selftests done, Tests total: 34, Tests passed: 23, Tests not passed: 11 |
07-16-2009, 16:57 | #10 (permalink) |
Crazy Poster Join Date: Sep 2006
Member: 346364 Status: Offline Thanks Meter: 12 | Strange things... SX4 work today... N72 and 6131 done with SX4. Guys You have bad simlock area. I have 3500c & 7370 with SX4 auth filed. But selftest - is ok. Only RPL solve the problem. |
07-17-2009, 10:10 | #11 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bristol, UK
Member: 607045 Status: Offline Thanks Meter: 127 | sx4 authorised done but errorr MCU Version V ICPR72_08w47.1 MCU Date 23-01-09 Product RM-356 Manufacturer (c) Nokia IMEI 353205031792227 Mastercode 3231251116 IMEI Spare 3A35020513972202 IMEI SV 3335020513972232F9000000 CNT v 001, 29-12-08, Orange_UK, RM356 PSN CCI244357 Product Code 0576921 Basic Product Code 0578897 PSD 0000000000000000 LPSN 0 WLAN MAC 00247C513D0C APE SW V 11.0.009 APE Variant V 11.0.009 ROFS1V 11.0.009 11.0.008.239.04 APE Test rm356_ENO_x_2008wk42v0.034 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP ICPR72_08w47 Simlock Server SIMLOCK SERVER Simlock Key 2343300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23433F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23486F SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.478), Cyclone Box Team 2008, 2009 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Disconnected from Cyclone Server BB5 Unlock Started... MCU Version V ICPR72_08w47.1 MCU Date 23-01-09 Product RM-356 Manufacturer (c) Nokia IMEI 353205031792227 Mastercode 3231251116 Simlock Server SIMLOCK SERVER Simlock Key 2343300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23433F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23486F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900001FB7000527B4B84201D1910C28B18163C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.8.36.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits BB5 Unlock Failed -> Failed to Boot / Prepare Phone SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.478), Cyclone Box Team 2008, 2009 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Disconnected from Cyclone Server BB5 Unlock Started... MCU Version V ICPR72_08w47.1 MCU Date 23-01-09 Product RM-356 Manufacturer (c) Nokia IMEI 353205031792227 Mastercode 3231251116 Simlock Server SIMLOCK SERVER Simlock Key 2343300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23433F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23486F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900001FB7000527B4B84201D1910C28B18163C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.8.36.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits BB5 Unlock Failed -> Failed to Boot / Prepare Phone unlock done with MT BOX Phone is in: Local mode Model: RM-356 ( RM-356) V ICPR72_08w47.1/23-01-09/RM-356 (c) Nokia Production serial number CCI244357 Product code 0576921 Module code Basic production code 0578897 Flash code Order number Long production SN 0 MCU SW V ICPR72_08w47.1/23-01-09/RM-356/(c) Nokia HW 1101 PCI RFIC 17141715 DSP ICPR72_08w47 APE SW Core V 11.0.009 APE Variant V 11.0.009 ROFS1V 11.0.009 11.0.008.239.04 APE Test rm356_ENO_x_2008wk42v0.034 Retu 15 Tahvo 22 APE HW 256 APE ADSP SW 256 Content Pack v 001/29-12-08/Orange_UK/RM356 IMEI: 353205031792227 WARNING: VPP pin is not connected, disabling VPP. 353205031792227 V ICPR72_08w47.1/23-01-09/RM-356 (c) Nokia IMEI: 353205031792227 Operator: 8000000000000000 Profile bits: 2343300000000000 Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353205031792227.pm 353205031792227 Booting Phone... Searching loader RAPIDOv11_2nd.fg Status Successfull Failed to locate Dejan Card on PC. Trying Server connection... Using Account: dksl2hWT1L Connect... Resp: o/0110/hello there Login... OK, available count 280; busy, waiting... #pw+493655340086201+7# Sending code to phone 353205031792227 UNLOCK SUCCESSFULL Finished in 15s |
07-17-2009, 10:29 | #13 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | To unlock a 5800 you don't need the sx4 auth.. you must just use the calculation of the NCK codes.. just press power on on the mobile and wait 10 seconds before answering yes on calculate nck codes.. As well is always better open a new thread when you have a problem instead of Hijack the other people thread as became impossible for the supporters follow 2/3 people on the same thread BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
www.*************** not work | defa | Cyclonebox | 4 | 10-30-2009 12:29 |
www.*************** not work | defa | Cyclonebox | 0 | 10-29-2009 18:42 |
SX4 not working ??? | KhOliO | MT-BOX | 7 | 06-25-2007 10:18 |
SX4 not working | 468492DF | MT-BOX | 4 | 05-03-2007 13:39 |
Sx4 not working?!!! | meisam | MT-BOX | 3 | 01-29-2007 16:21 |
