07-13-2009, 12:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: iCloud ID Removed Service
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | Cyclonebox Team Plz Help Help N81 Unolcking failed not nck ??? Help me Thank Log: Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1450001972750052B0175C5D0D32634E15FCA8DA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600221, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Subsystem Not Found Restarting MCU... BB5 Unlock Started... MCU Version V 06wk41v62.4 MCU Date 04-12-08 Product RM-223 Manufacturer (c) Nokia IMEI 351935031243829 Mastercode 3363306056 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1450001972750052B0175C5D0D32634E15FCA8DA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600221, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1450001972750052B0175C5D0D32634E15FCA8DA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... BB5 Unlock Failed -> Failed to get Lock Key (6); B.R LIEREN |
The Following User Says Thank You to LIEREN For This Useful Post: |
07-13-2009, 20:21 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | just use tma adapter for a stable local mode and do the unlock answering no when asked to calculate codes.. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-14-2009, 06:44 | #9 (permalink) |
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | @NADEEM GONDAL THANK YOU! yes,me Use Tma Adaptor ok ,100% |
07-14-2009, 07:05 | #10 (permalink) |
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | @NADEEM GONDAL thank you Do The Unlock Answering No When Asked To Calculate Codes.. ? yes? |
07-14-2009, 07:09 | #11 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | The n81 is supported in both modes.. If is supported by NCK use NCK.. if it fails do the job answering NO when asked to calculate the codes. BR Alex |
07-14-2009, 07:18 | #13 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | ok lieren.. now connect the TMA adapter to the yellow adapter, select only 2 on the switch board, plug the usb cable of the TMA adapter in a free port of you computer and try again the unlock. Start answering yes when asked for the NCK codes.. before doing click on yes, give time to the mobile (about 5 seconds) to go in local mode then click on yes. Should go ok smootly. If you get error try answering no when asked to calculate the codes. the model is supported for both the unlock system. BR Alex |
07-14-2009, 22:31 | #14 (permalink) |
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | @moulnisky your the help, I very much appreciated!!! thanks How to solve? my n81 phone start-up failed.Contact the retailer.problem |
infinty team plz urgent help | faisal_fs | Infinity-Box | 5 | 12-07-2012 08:27 |
Cyclonebox TEAM PLZ | .::allgsmkey::. | Cyclonebox | 0 | 10-12-2009 20:51 |
infinty team plz urgent help me | faisal_fs | Infinity-Box | 4 | 07-29-2009 08:21 |
infinity team plz urgent help me. . . . . | aamirgsm | Infinity-Box | 2 | 11-03-2008 22:49 |
UN. team plz urgent help | roro_manool | Universalbox | 3 | 04-24-2007 04:07 |
