05-30-2010, 05:10 | #1 (permalink) | |
Major Poster Join Date: Apr 2008
Member: 758704 Status: Offline Thanks Meter: 2 | DEAD 5130c, PLEASE help me to REVIVE ACTION TAKEN : Flash USING Cyclone but Quote:
HERES the LOGS Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.37, (Apr 22 2010 23:09:11, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk16 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: Cypercrue HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: Cypercrue Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.17v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.05v PASSED VBAT Voltage 5.09v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.19v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 13000119A9447F56EB3ECE8D11175E19E22B84E0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Not erased CMT HWC Not erased CMT CCC Not erased CMT R&D Not erased CMT VARIANT Not erased CMT PAPUBKEYS Not erased CMT KEYS Not erased Restarting MCU... Erase all certificates finished Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 13000119A9447F56EB3ECE8D11175E19E22B84E0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Not Found CMT CCC Not Found CMT HWC Not Found CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm495__06.65.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 13000119A9447F56EB3ECE8D11175E19E22B84E0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__06.65.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 0.312s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm495__06.65.mcusw | |
The Following User Says Thank You to cypercrue For This Useful Post: |
05-30-2010, 05:21 | #2 (permalink) | |
Member: 758704 Status: Offline Thanks Meter: 2 | TRY to READ in JAF HERES the LOGS Quote:
is there posibilities to revive dead 5130c-2? | |
05-30-2010, 12:22 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm495__06.65.mcusw ----------- Tx2 problem .. check your yellow adopter |
The Following User Says Thank You to SiRoYa For This Useful Post: |
05-31-2010, 09:27 | #6 (permalink) | |
Freak Poster Join Date: May 2004 Location: Silent Mode Age: 39
Member: 65656 Status: Offline Thanks Meter: 91 | Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... USB Voltage 4.93v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.75v PASSED VBAT Voltage 1.34v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing D:\Program Files\Nokia\Phoenix\Products\... Found 47 products, Filtering BB5 Products - wait... 25 Products left after filtering. Ready. Retrieving Variants for Product RM-495 - wait... 399 Variants Retrieved Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 262001133FEF7D566FF7671B77126A4C1ECD07D8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm495__07.91.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 262001133FEF7D566FF7671B77126A4C1ECD07D8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.91.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 27.109s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 57.687s Flashing Speed: 2646.12 kBit/S Restarting MCU... Processing rm495__07.91.mcusw (APE)... Processing rm495__07.91.ppm_x (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 262001133FEF7D566FF7671B77126A4C1ECD07D8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.91.ppm_x, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Waiting 320s for erasure finish... Erase taken 30.719s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 20.281s Flashing Speed: 3191.05 kBit/S Restarting MCU... Processing rm495__07.91.ppm_x (APE)... Processing rm495__07.91.image_x_blu (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 262001133FEF7D566FF7671B77126A4C1ECD07D8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.91.image_x_blu, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 79.109s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 43.172s Flashing Speed: 2504.64 kBit/S Restarting MCU... Processing rm495__07.91.image_x_blu (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 07.91 MCU Date 29-10-09 Product RM-495 Manufacturer (c) Nokia IMEI Mastercode 5574245457 IMEI Spare IMEI SV PPM V 07.91, 29-10-09, RM-495, (c) Nokia , X CNT Content: x_blu, V 07.91, 29-10-09, RM-495, (c) Nokia , PSN IMN068772 Product Code 0578116 Module Code 0204024 Basic Product Code 0567773 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2000 RFIC 06540601 DSP ICPR72_09w33 LCD SEIKO BT 2222-302 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Quote:
05-31-2010, 09:28 | #7 (permalink) |
Member: 758704 Status: Offline Thanks Meter: 2 | thanks for the reply the phone is working now i FLASH it USING JAF.... now its ALIVE but STILL CONTACT SERVICE... HOPE that CYCLONE TEAM work for the SL3 Unlocking & FIXING the CONTACT SERVICE (5130c-2 and other SL3) UPDATE: the 5130c-2 is WORKING now after clicking (DOWNGRADE) Fast Repair in CYCLONE but the IMEI is DAMAGE already... but the good this is that PHONE IS ALIVE (but IMEI is 12345610654321?) the bad this is sometimes when you're playing music or videos the phone restart... THANKS for the REPLY BR cypercrue |
05-31-2010, 09:31 | #8 (permalink) |
Member: 758704 Status: Offline Thanks Meter: 2 | here's the logs Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.37, (Apr 22 2010 23:09:11, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk16 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: CYPERCRUE HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: CYPERCRUE Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.19v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.05v PASSED VBAT Voltage 5.07v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.19v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 07.91 MCU Date 29-10-09 Product RM-495 Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452341F7000000 PPM V 07.91, 29-10-09, RM-495, (c) Nokia , EL CNT Content: el_blu, V 07.91, 29-10-09, RM-495, (c) Nokia , PSN IMN186716 Module Code 0204024 Basic Product Code 0567773 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2000 RFIC 06540601 DSP ICPR72_09w33 LCD SEIKO BT 2222-302 Failed to read info -> Failed to read SP info cypercrue Last edited by ptt; 05-31-2010 at 18:45. Reason: Code Tag |
05-31-2010, 09:33 | #9 (permalink) |
Member: 758704 Status: Offline Thanks Meter: 2 | ANALYZE SECURITY LOGS Code: Started Phone Security Analysis... MCU Version V 07.91 MCU Date 29-10-09 Product RM-495 Manufacturer (c) Nokia IMEI 12345610654321? Reading Security Block... Security block OK and saved to "RM-495_12345610654321_5312010_21909 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "13000119A9447F56EB3ECE8D11175E19E22B84E0.C000180B" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! JAF LOGS Code: Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.29.0 Changing mode...Done! Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006030C192101033000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 13000119A9447F56EB3ECE8D11175E19E22B84E0 HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89820089 <=> INTEL -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 07.91 29-10-09 RM-495 (c) Nokia HW version: 2000 PCI version: RFIC version: 06540601 DSP version: ICPR72_09w33 LCD version: SEIKO PPM version: V 07.91 29-10-09 RM-495 (c) Nokia EL BT MCM version: 2222-302 Retu version: 16 Tahvo version: 22 Content Pack version: Content: el_blu V 07.91 29-10-09 RM-495 (c) Nokia Production serial number: IMN186716 Product code: Module code: 0204024 Basic production code: 0567773 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 41 F7 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-495.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-495\ Searching for default location of ini... Checking path: \Products\RM-495\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-495\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! cypercrue Last edited by ptt; 05-31-2010 at 18:46. Reason: Code Tag |
05-31-2010, 09:46 | #11 (permalink) | |
Insane Poster Join Date: Nov 2008
Member: 896305 Status: Offline Thanks Meter: 17 | i got the same error Quote:
pls team fix this in the next update | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
