11-05-2009, 06:06 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 275590 Status: Offline Thanks Meter: 41 | E63 successfully unlocked Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.09, (Oct 28 2009 15:56:27, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C0000C43 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D200044D Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.62v PASSED VBAT Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D90010E157E00520C3EEC36E1BE2CA78C513CB3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Not Found CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished BB5 Unlock Started... MCU Version V ICPR71_09w22 MCU Date 29-05-09 Product RM-450 Manufacturer (c) Nokia IMEI 359318021040103 Mastercode 547520331 Simlock Server SIMLOCK SERVER Simlock Key 5050600042465540 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50506F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 50599F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 50506F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 50599F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 00101F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 00101F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D90010E157E00520C3EEC36E1BE2CA78C513CB3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D90010E157E00520C3EEC36E1BE2CA78C513CB3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Bypassing SX4... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D90010E157E00520C3EEC36E1BE2CA78C513CB3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits CMT NPC Ok CMT NPC Erased Restarting MCU... Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1D90010E157E00520C3EEC36E1BE2CA78C513CB3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restoring NPC... Restarting MCU... SX4 Bypass Finished MCU Version V ICPR71_09w22 MCU Date 29-05-09 Product RM-450 Manufacturer (c) Nokia IMEI 359318021040103 Mastercode 547520331 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! |
The Following User Says Thank You to thirunilavan For This Useful Post: |
11-05-2009, 08:47 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Just have a look at this stricky post http://forum.gsmhosting.com/vbb/showthread.php?t=811470 BR Alex |
Nokia E63 Successfully Unlocked !! | quinzinho | BB5 Box by D.K. | 44 | 04-01-2012 09:19 |
Problem with my E63 | jasmine88 | Cyclonebox | 0 | 03-30-2010 16:19 |
E63 successful unlock with mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-01-2010 13:19 |
