heres the log of flashing without ticking new downgrade PHP Code: Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical Failed to Create RPL from phone -> Failed to read Security Block RPL backup thread finished, continuing... Backing up simlock... MCU Version V ICPR82_11w16.3.11 MCU Date 29-03-12 Product RM-530 (Nokia E72) Manufacturer (c) Nokia IMEI 355239031909745 Mastercode 6447267160 Simlock backup OK, saved to RM-530_355239031909745_9142012_81632 PM.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm530_091.004_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND EraseArea[0,CMT]: 0x008E0000-0x0E77FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.203s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 123.828s Flashing Speed: 7240.62 kBit/S Restarting MCU... Processing rm530_091.004_prd.core.fpsx (APE)... Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x07CC0000-0x0CDBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.422s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 66.172s Flashing Speed: 7314.68 kBit/S Restarting MCU... Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (APE)... Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0CDC0000-0x0E77FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.156s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 9.782s Flashing Speed: 7229.08 kBit/S Restarting MCU... Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (APE)... Processing rm530_091.004_U007.000_prd.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm530_091.004_U007.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0E780000-0x1F13FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 1.406s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 17.47s Flashing Speed: 6730.31 kBit/S Restarting MCU... Processing rm530_091.004_U007.000_prd.uda.fpsx (APE)... Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 3.78s Flashing Speed: 7044.23 kBit/S Restarting MCU... Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V ICPR82_11w16.3.11 MCU Date 29-03-12 Product RM-530 (Nokia E72) Manufacturer (c) Nokia IMEI 355239031909745 Mastercode 6447267160 IMEI Spare 3A55320913097904 IMEI SV 3355320913097964F1000000 PSN CFM136975 Product Code 0587035 Basic Product Code 0583552 PSD 0000000000000000 LPSN 0 WLAN MAC 347E39980FD6 RETU 40 TAHVO 00 AHNE 11 HW 0803 Failed to read info -> Failed to read extended info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished!
