Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-14-2012, 08:35   #1 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
E72 need help!
help me how to fix this please!
unit came to us already dead and reprogrammed by other tech..
check this:
All initialized - Ready to work
MCU Version V ICPR82_11w16.3.11
MCU Date 29-03-12
Product RM-530 (Nokia E72)
Manufacturer (c) Nokia
IMEI 355239031909745
Mastercode 6447267160
IMEI Spare 3A55320913097904
IMEI SV 3355320913097964F1000000
PSN CFM136975
Product Code 0587035
Basic Product Code 0583552
PSD 0000000000000000
LPSN 0
WLAN MAC 347E39980FD6
APE SW 091.004
APE Variant 091.004091.004.41.01091.004.C00.01
APE Test v0.a038
APE HW 256
APE ADSP 256
RETU 40
TAHVO 00
AHNE 11
HW 0803
Failed to read info -> Failed to read extended info
Started Phone Security Analysis...
MCU Date 29-03-12
Reading Security Block...
Security block OK and saved to "RM-530_355239031909745_9142012_33758 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"1D90020E12650344C98E23E6322CEEB4A4A22831.C0000391 " Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Old 09-14-2012, 10:20   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
read the mobile's PM and post it here please
Alex
Old 09-14-2012, 10:42   #3 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
sir its always failed when reading it, but i have found backup from cyclone stored files
can you check it?
Old 09-14-2012, 11:00   #4 (permalink)
moulnisky's Avatar
Member: 947561
the simlock looks fine and same looks the security
try flashing it with the version 91.4 with "new downgrade" ticked
please report
Alex
Old 09-14-2012, 13:06   #5 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
Warning: Failed to Read PM Record 107,26
Failed to read PM -> Failed to get PM Key 108 Length
Failed to Proceed with New Downgrade -> Failed to Read PM
sir this is what i got when i try it to flash again..
Old 09-14-2012, 13:08   #6 (permalink)
moulnisky's Avatar
Member: 947561
please, pass me via private message your teamviewer details: I would be pleased to have a look at it together in remote assistance
Alex
Old 09-14-2012, 13:24   #7 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
heres the log of flashing without ticking new downgrade
PHP Code:
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Read Security Block Problem -> Failed to read PM 308this is critical
Failed to Create RPL from phone
-> Failed to read Security Block
RPL backup thread finished
continuing...
Backing up simlock...
MCU Date    29
-03-12
Product        RM
-530 (Nokia E72)
Manufacturer    (cNokia
Simlock backup OK
saved to RM-530_355239031909745_9142012_81632 PM.SLBackup.PM
Backup simlock thread finished
continuing...
Pre flash tasks finishedcontinuing...
Processing rm530_091.004_prd.core.fpsx (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID:    000000030000022600010007600C192102011104
CMT_EM_ASIC_ID
:        00001040
CMT_EM_ASIC_ID
:        00001030
CMT_PUBLIC_ID
:        1D90020E12650344C98E23E6322CEEB4A4A22831
CMT_ASIC_MODE_ID
:    00
CMT_ROOT_KEY_HASH
:    25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC
:    3E273BF6
CMT_SECURE_ROM_CRC
:    37BE26FA
CMT Ready
rm530_091.004_prd.core.fpsxTypeFlash ImageAlgoXSR 1.6BB5
Searching
for BootCodeDualLine 32Bit
RAPUv11_2nd
.fgType2nd Boot LoaderRev768.12.11.0AlgoBB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using
NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by LoaderDual Line32 bitOverriding
Dual Line32 bitAcceptedDual Line32 bit
Box TX2 Data Pin set to
Service Pin 3
If software STUCK HERE with box TX LED litthat means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases
you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000UnknownRAM
FlashChip
[0,CMT]: 0xFFFF000000000000UnknownMMC
FlashChip
[0,CMT]: 0x0000000000000000UnknownNOR
FlashChip
[1,CMT]: 0x0000000100000000UnknownNOR
FlashChip
[0,CMT]: 0x00EC005800000121SamsungONENAND
Requested Algorithm
XSR 1.6 (CMT)
Searching for BootCodeDualLine 32Bit
FlashChip 0x00EC0058
(Samsung), Size512MBytesVPPNot Supported
RAPUv11_XSR17_alg
.fgTypeAlgorithmRev768.12.11.0AlgoXSR 1.6
Initializing TurboCache
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Default
Service Pin 3
Adding FUR Client
(CMTStateReady)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash
for CMT660D81A4455F6F7F9B81D5D10F5336B14B50635E
Flashbus Write baud set to 5.0Mbits
Sending Certificates
Certificates OK
Partitioning
Partitioning OK
Started group flash erase
EraseArea
[0,CMT]: 0x00020000-0x0003FFFFONENAND
EraseArea
[0,CMT]: 0x00060000-0x004DFFFFONENAND
EraseArea
[0,CMT]: 0x008E0000-0x0E77FFFFONENAND
Erase Partition
(CMT)
Waiting 320s for erasure finish...
Erase taken 1.203s
Writing all blocks
Initializing TurboCache...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OKTime taken 123.828s
Flashing Speed
7240.62 kBit/S
Restarting MCU
Processing rm530_091.004_prd.core.fpsx (APE)...
Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (CMT)...
Booting CMT...
CMT_EM_ASIC_ID
:        00001040
CMT_EM_ASIC_ID
:        00001030
CMT_PUBLIC_ID
CMT_ASIC_MODE_ID
:    00
CMT_ROOT_KEY_HASH
CMT_BOOT_ROM_CRC
:    3E273BF6
CMT_SECURE_ROM_CRC
:    37BE26FA
CMT Ready
rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsxTypeFlash ImageAlgoXSR 1.6BB5
Searching
RAPUv11_2nd
Using
Service Pin 3
In either cases
FlashChip
FlashChip
FlashChip
FlashChip
Requested Algorithm
XSR 1.6 (CMT)
RAPUv11_XSR17_alg
TurboCache Loaded!
Default
Service Pin 3
Adding FUR Client
(CMTStateReady)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash
Certificates OK
EraseArea
[0,CMT]: 0x07CC0000-0x0CDBFFFFONENAND
Waiting 320s
Erase taken 0.422s
Writing all blocks
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OKTime taken 66.172s
Flashing Speed
7314.68 kBit/S
Restarting MCU
Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (APE)...
Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT_EM_ASIC_ID
:        00001040
CMT_EM_ASIC_ID
:        00001030
CMT_PUBLIC_ID
CMT_ASIC_MODE_ID
:    00
CMT_ROOT_KEY_HASH
CMT_BOOT_ROM_CRC
:    3E273BF6
CMT_SECURE_ROM_CRC
:    37BE26FA
CMT Ready
rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsxTypeFlash ImageAlgoXSR 1.6BB5
Searching
RAPUv11_2nd
Using
Service Pin 3
In either cases
FlashChip
FlashChip
FlashChip
FlashChip
Requested Algorithm
XSR 1.6 (CMT)
RAPUv11_XSR17_alg
TurboCache Loaded!
Default
Service Pin 3
Adding FUR Client
(CMTStateReady)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash
Certificates OK
EraseArea
[0,CMT]: 0x0CDC0000-0x0E77FFFFONENAND
Waiting 320s
Erase taken 0.156s
Writing all blocks
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OKTime taken 9.782s
Flashing Speed
7229.08 kBit/S
Restarting MCU
Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm530_091.004_U007.000_prd.uda.fpsx (CMT)...
Booting CMT...
CMT_EM_ASIC_ID
:        00001040
CMT_EM_ASIC_ID
:        00001030
CMT_PUBLIC_ID
CMT_ASIC_MODE_ID
:    00
CMT_ROOT_KEY_HASH
CMT_BOOT_ROM_CRC
:    3E273BF6
CMT_SECURE_ROM_CRC
:    37BE26FA
CMT Ready
rm530_091.004_U007.000_prd.uda.fpsxTypeFlash ImageAlgoXSR 1.6BB5
Searching
RAPUv11_2nd
Using
Service Pin 3
In either cases
FlashChip
FlashChip
FlashChip
FlashChip
Requested Algorithm
XSR 1.6 (CMT)
RAPUv11_XSR17_alg
TurboCache Loaded!
Default
Service Pin 3
Adding FUR Client
(CMTStateReady)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash
Certificates OK
EraseArea
[0,CMT]: 0x0E780000-0x1F13FFFFONENAND
Waiting 320s
Erase taken 1.406s
Writing all blocks
TurboCache Loaded!
All blocks written OKTime taken 17.47s
Flashing Speed
6730.31 kBit/S
Restarting MCU
Processing rm530_091.004_U007.000_prd.uda.fpsx (APE)...
Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (CMT)...
Booting CMT...
CMT_EM_ASIC_ID
:        00001040
CMT_EM_ASIC_ID
:        00001030
CMT_PUBLIC_ID
CMT_ASIC_MODE_ID
:    00
CMT_ROOT_KEY_HASH
CMT_BOOT_ROM_CRC
:    3E273BF6
CMT_SECURE_ROM_CRC
:    37BE26FA
CMT Ready
RM530_ENO_APE_ONLY_09wk35_v0.038.fpsxTypeFlash ImageAlgoXSR 1.6BB5
Searching
RAPUv11_2nd
Using
Service Pin 3
In either cases
FlashChip
FlashChip
FlashChip
FlashChip
Requested Algorithm
XSR 1.6 (CMT)
RAPUv11_XSR17_alg
TurboCache Loaded!
Default
Service Pin 3
Adding FUR Client
(CMTStateReady)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash
Certificates OK
EraseArea
[0,CMT]: 0x004E0000-0x008DFFFFONENAND
Waiting 320s
Erase taken 0.47s
Writing all blocks
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OKTime taken 3.78s
Flashing Speed
7044.23 kBit/S
Restarting MCU
Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (APE)...
All images processed OKProcessing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info
MCU Date    29
-03-12
Product        RM
-530 (Nokia E72)
PSN        CFM136975
LPSN        0
RETU        40
TAHVO        00
AHNE        11
HW        0803
Failed to read info
Read info thread finished
continuing...
Post flash tasks finished!
Flashing successfully finished
Old 09-14-2012, 13:42   #8 (permalink)
Registered User
Member: 777512
Sonork: zOOm25
Thanks Meter: 9
PM sent sir.. Thanks!
Page generated in 0.35272 seconds with 9 queries
