01-24-2010, 12:50 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: east peckham, near tonbridge
Member: 505845 Status: Offline Thanks Meter: 21 | Help after flash PM, i believe pm file was not in english Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number xxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown Initializing security card...xxxxxx Card Serial Number: Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.12v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.18v PASSED VBAT Voltage 5.09v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 05.50 MCU Date 07-07-05 Product RH-12 Manufacturer GSM P1.1, (c) NMP. IMEI 352953008290797 Mastercode 3754344514 IMEI Spare 3A25590380927009 IMEI SV 3325590380927019F7000000 PPM V 05.50, 07-07-05, RH12_28_-, GSM P1.1, E CNT V 05.50\n07-07-05\nRH12_28_-\nGSM P1.1\n(c) NMP. PSN KKH527820 Product Code 0513093 Module Code 0201879 Basic Product Code 0509076 PSD 0000001700000000 HW 0600 UEM 288 UPP 4178 RFIC p10ff11ff0200 DSP pB0435T_04w46 LCD SHARP ADSP Sw pMATRIX_04_w35_prod_w46 Failed to read info -> Failed to read SP info This is what i got when conected phone again after bad flash, and on the phone screen when i switch it on is , CONTAC SERVICE |
01-24-2010, 12:59 | #2 (permalink) | |
Member: 505845 Status: Offline Thanks Meter: 21 | I have same problem with 6230 dct4 Quote: | |
01-24-2010, 13:58 | #3 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | 6230 dead after pm file flash ive got a 6230 which i flashed succesfuly, but needed to flash PM, so did this, then had contact service on screen, so tried to reflash but now phone not switch on, also cyclone software not detect phone, please help revive phone, if i need te erase flash files, please give step by step instrutions as im a beginner with cyclone, all help all ways thankeddd |
01-24-2010, 19:43 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Which PM file you write to the Phone ? and for what reason you write PM to the Phone ? BR |
The Following User Says Thank You to ptt For This Useful Post: |
01-24-2010, 19:59 | #6 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | You sure the PM file that you write is OK ? Have you any PM bakup, before write the downloaded PM file ? |
01-24-2010, 20:05 | #7 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | Next to PM file, said good file the file said good pm file next to it in gsm, but obviousley no good, and No never done back up, some people tell do some tell dont, Im getting all my info from the gsm forum, so to get the best info, but this is not the case, many thnak |
01-24-2010, 20:19 | #9 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | The problem is phone not detected The only problem is when i conect phone, and start software, and do check info, the software not detedt phone now, so wont turn on at all,how can i revive this, many many thanks,,, |
01-24-2010, 20:24 | #10 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Full flash again your Phone Try to do a "check flashing Bus" if it is OK, then you can flash the mobile, even if cant read phone Info BR |
01-24-2010, 20:40 | #11 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | I will try, many thanks Thanks mate, i will try this tomorrow, and will let you know the result, it is so good to know there are people out there who are there to help us beginners, will thank, and let you know, many many thanks |
01-24-2010, 20:44 | #12 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | Befor i go, can you.... As you are the best for info. please give me link for flash file needed so i know its a GOOD ONE, 6230, many thanks will let you know what happens, |
01-24-2010, 20:56 | #13 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Here you have the last version for the 6230 RH-12 v5.50 : http://rapidshare.com/files/16344001..._0550_6230.exe try selecting this files for flash: MCU: rh12_28_11005.500 PPM: rh12_28_11005.50c CNT: rh12_28_11005.50.ucp_c BR Last edited by ptt; 01-24-2010 at 21:09. |
01-25-2010, 19:24 | #14 (permalink) | |
Member: 505845 Status: Offline Thanks Meter: 21 | qown loaded file Quote:
01-25-2010, 19:28 | #15 (permalink) |
Member: 505845 Status: Offline Thanks Meter: 21 | log here for check All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 1052 [HW_TIKUEDGE_v1_1] Flashbus Write baud set to 100Kbits te_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: TIKU BT2 PLL Factor: 1 FlashChip[0]: 0x00EC22F8 @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000011 FlashChip[1]: 0x00EC0039 @ 0x02000000, Samsung, SectorSize: 576kB, Ext: 00000000 Signature: 0000000018F09FE518F09FE518F09FE5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits te_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC22F8 (128Mbits), Rev: 7.4.76.0, Algo: TIKU ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 6.349s Check Flashing Bus finished |
help me the mfi file was not found on the local drive | dilpreetraju | BlackBerry (RIM) | 3 | 12-21-2009 01:53 |
help..mfi file was not found ABORT | MYUNLOCKING | BlackBerry (RIM) | 8 | 02-24-2009 01:03 |
cect p168 flash file was not found in infinity box | guljee786 | Infinity-Box | 1 | 01-05-2009 22:04 |
mfi file was not found in local drive | sam1970 | BlackBerry (RIM) | 10 | 12-30-2008 16:02 |
flash file was not right | ahmertelecom | UST Pro II | 0 | 08-31-2007 17:42 |
