07-13-2009, 01:15 | #1 (permalink) |
Insane Poster Join Date: Mar 2006 Location: Rahba Constantine Shop N°8 SG
Member: 247200 Status: Offline Sonork: 1580769 Thanks Meter: 42 | Hot Fix Contact service In BB5 Phone Just 3-5 short click. You must have the latest version pack of cyclone box. -connect your phone. -Then go to bb5 & security tab -Use rebuild RPLFrom Phone and wait the time of generating RPL. after that cyclone give you the choice to save rpl file. -Save your file. -after that try to write the Rpl With checking plain rpl and erase security. Finally power your phone with battery and magically Contact service is gone. |
The Following 8 Users Say Thank You to bobosoft For This Useful Post: |
07-13-2009, 01:55 | #2 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | contact service not same in every phone, better to do self test first and see what test fails. br. |
The Following User Says Thank You to gsmbac For This Useful Post: |
07-13-2009, 06:11 | #7 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | 2. for bb5 not only yellow cable to be needed but it is including backup rpl, pm, certificate. 3. we do trade on 100% cyclone to solve all phone. try another software. still remeber, before do anything, backu rpl pm crt. ext. just my opinion |
07-13-2009, 23:30 | #9 (permalink) |
Member: 247200 Status: Offline Sonork: 1580769 Thanks Meter: 42 | We are speaking about contact service... We are speaking about contact service when the security zone is damaged. so when you do self test you get fail in sec zone this solution rebuild sec zone. for destroyed imei you must read ask and post it to get real rpl with full config key and imei number and fbus counter rested. in dct4 with cyclone you can calculate full RPl they took 1 credit in dct-4 and 2 credits in dct4+. good luck |
The Following 2 Users Say Thank You to bobosoft For This Useful Post: |
09-06-2009, 10:30 | #10 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1063170 Status: Offline Thanks Meter: 5 | hi friends can any1 help me i m stucked with 5310 nokia RM-303 since many days in the process of unlocked, mobile got imei 123456... and then contact service now after writing certificates and flashing... i get this problem here is the log Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101013000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E800104AB535A5092B1D1AD5750515D1EBD8A00 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... MCU Version V 09.42 MCU Date 07-11-08 Product RM-303 Manufacturer (c) Nokia IMEI 356870026819785 Mastercode 6721753172 IMEI Spare 3A65780062187908 IMEI SV 3365780062187968F1000000 PPM V 09.42, 07-11-08, RM-303, (c) Nokia , Q CNT Content: q_whitemica_silver, V 09.42, 07-11-08, RM-303, (c) Nokia , PSN KIT083549 Product Code 0566173 Module Code 0203414 Basic Product Code 0544850 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 2020 RFIC 06540609 DSP ICPR71_08w30 LCD SEIKO BT 2222-143 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Failed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_BTEMP_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 29, Tests passed: 26, Tests not passed: 3 After reading here in forums i tried SX Authorize and then here is the log, but same problem Contact Service Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Disconnected from Cyclone Server Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Failed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_BTEMP_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 29, Tests passed: 27, Tests not passed: 2 thanx brother |
09-06-2009, 22:28 | #12 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
BR Alex | |
09-08-2009, 02:28 | #13 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Kumasi,Ghana
Member: 448929 Status: Offline Sonork: 100.1573624 Thanks Meter: 20 | Quote:
09-08-2009, 03:55 | #14 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | The 3500c is a BB5 SL1 phone Rap3gv3 is better to fix the contact service problem you follow the guidelines of this othe post http://forum.gsmhosting.com/vbb/showthread.php?t=816420 BR Alex |
what is the root cause of contact service for bb5 phones? | GSMaxx | Nokia Base Band 5 ( BB-5 ) | 4 | 11-24-2009 03:44 |
how to fix the problem contact service in 5220,7210s??? | rahulk99k | Nokia Base Band 5 ( BB-5 ) | 1 | 08-30-2009 10:04 |
fix contact services in 2610 after unlocking | gsmservices | MT-BOX | 1 | 01-21-2007 05:41 |
Reparing contact service in TDMA phones | miq | Twisterflasher | 3 | 08-11-2004 14:53 |
