08-04-2009, 14:07 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1073012 Status: Offline Thanks Meter: 0 | How can I get local/Test mode on BB5 fones using TMA adapter I am trying to unlock nokia N70, I have connected TMA adapter (Black end) to cyclone yellow adapter, I have tried 2.2 and 3.3 but the phone still the same thing can't get any local or test mode. Cheers |
08-04-2009, 15:25 | #2 (permalink) |
Freak Poster Join Date: Jan 2004 Location: newcastle under lyme,staffs
Member: 48245 Status: Offline Thanks Meter: 27 | hi you need plug in the red cable on the TMA adapter for use with cyclone the black cable is for mt box ( 10 pin) not sure on the correct bsi level - try 10 |
08-04-2009, 16:13 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You must unplug the fbus from the TMA every time you try a value.. remember all the switches mus be in OFF apart the one you need as added value. The USB cable of the TMA, if present, must be connected to a free usb port of the computer. If you are using an UFC cable, leave only the 1 on on the TMA and do the tests using different values on the UFC as BSI. BR Alex |
08-04-2009, 17:51 | #4 (permalink) |
Member: 1073012 Status: Offline Thanks Meter: 0 | Hi, I have connected cyclone + yellow cable + TMA adapter red + JAF N70 adapter + Nokia N70 adapter, I left 5 on (5.1) but still can't unlock. Do I have to connect usb cable too. Cheers |
08-04-2009, 18:16 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | i say when using TMA with old BB5 phones... Check Flashing BUS and also Set value to 7.5k works all the time...be sure ur cable fitted properly as well |
New bb5 cables and Local/Test Mode | Alwed | HWK | 2 | 10-08-2006 15:16 |
6230 can make LOCAL/TEST MODE | Spacewalker | Nokia Hardware & Hardware Repair | 0 | 02-21-2005 14:54 |
How can I enter to Service Mode on C65??? | syciu | S-Gold Based Phones | 8 | 12-23-2004 23:51 |
How can I get in service menu on myX-5m? | foony | ARM9 BASED M62 / M62+ | 1 | 04-09-2003 21:02 |
