Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-17-2009, 01:59   #1 (permalink)
Member: 200475
Thanks Meter: 37
How to use JAF universal cable with cyclonebox
Hi
I use to use JAF universal cable for E75. After the connection, I can see the phone comes up "local mode" but can't be detected by the program.
Do I need to use the adaptor just like other BB5 ?
What BSI I should use ? 10, 7.5, 5.1 3.3 ?
Any other special setting for the program ?
pls adivce. tks
SS
Old 11-17-2009, 02:03   #2 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
For BB5 phones, you need to use the TX2 adapter (the yellow ones)
Old 11-17-2009, 02:10   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,049
BSI 7,5 kohm
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 11-17-2009, 02:15   #4 (permalink)
Member: 200475
Thanks Meter: 37
Originally Posted by moulnisky View Post
BSI 7,5 kohm
Alex
I use the adaptor and made the right connection and the phone up "local model" already. however, can't get info or can't check FBus.
pls advice. tks.
SS
Old 11-17-2009, 02:19   #5 (permalink)
JHUNpanabO's Avatar
Member: 265729
Thanks Meter: 144
is this for unlock process,
if not detect it, change other
cable,to avoid problem in future,
Old 11-17-2009, 02:26   #6 (permalink)
Member: 200475
Thanks Meter: 37
Yes. I want to unlock the phone. Actually, I am being told JAF universal cable can be used before I bought the box but just don't know what is happening to this model.
tks
SS
Old 11-17-2009, 18:22   #7 (permalink)
moulnisky's Avatar
Member: 947561
Try the Jig N. 6.
In some cables the name of the jig change
Alex
Old 11-18-2009, 05:01   #8 (permalink)
Member: 200475
Thanks Meter: 37
Try the Jig N. 6.
Alex
Yes. that is the one I can get "local mode" come up following your pinout and BSI value. However, no responce for "info" or "check Fbus" under BB5 or DCT 4.
pls advice. tks
SS
Old 11-19-2009, 03:43   #9 (permalink)
Member: 200475
Thanks Meter: 37
Any solution ?
tks
Ss
Old 11-19-2009, 03:53   #10 (permalink)
Member: 744027
Thanks Meter: 5
has anybody can share the problem in this phone
Old 11-19-2009, 13:58   #11 (permalink)
Member: 200475
Thanks Meter: 37
Please address the problem and provide proper solution
Forget to point out, I can use nokia 2760 easy cable to unlock and I can use Normal JAF 7 pins to read and unlock other BB5 phones. Except this one, I don't have the right cable, that's why I use the universal one. When I try to read in JAF, it works, so, definitely it's not the cable or connection problem. It's just about can't read under your program. However, I am wondering, normally if there is any problem with the cable or connection, the phone shouldn't come up local mode, but as I mentioned before it comes up all the time no matter I use the 5 pins or 7 pins cable. just not reading info and can't process any unlocking etc..
I read the forum, there are many similer cases that the phones do go to local model but then can't read or unlock etc.. This is a fun*****tal problem that really have to resolve as I am also being told universal cable can 't used BEFORE I buy your box.
Please address the problem and give us a solution.
Old 11-21-2009, 17:00   #12 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Try `check flashing bus` first, after this try reading out phone by FBUS interface.
Old 11-23-2009, 02:59   #13 (permalink)
Member: 200475
Thanks Meter: 37
Yes. I did try this but no responce as well. Again, the phone is under local model all the time but no responce either check flashing bus or Info.
pls advice.
SS
Old 11-23-2009, 03:01   #14 (permalink)
Member: 1166709
Thanks Meter: 21
seems to be the right one.thanks mr
Old 11-23-2009, 03:16   #15 (permalink)
Member: 200475
Thanks Meter: 37
Yes. But it is not. Again. I did try this but no responce as well. The phone is under local model all the time but no responce either check flashing bus or Info.
SS
How to Use DITS Universal Cable COOL_RONIT PRODUCTS SUPPORT 3 06-17-2010 21:55
How to use DKU-2 cable with ufs-3 parvezjk Nokia Hardware & Hardware Repair 5 02-27-2009 19:23
how to use sony ericsson cable with testpoint bentys2000 UFS2 + UFS3-Tornadoflasher 2 08-30-2004 18:43
How to use siemens griffin cable with other proggies? Uvedovle Griffin 5 03-17-2004 10:12
How to use t100 orig. cable with a800 olegario VLSI, Conexant, Skyworks and Old Models 5 08-23-2003 10:10
Page generated in 0.21230 seconds with 9 queries
