10-29-2012, 11:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | Nokia 500 flashing problem I try flashing Nokia 500 using Fbus cable: Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: xxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: xxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,07v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,77v PASSED VBAT Voltage 1,38v PASSED VBAT Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 98 Avaiable Physical Memory: 566.968MB Avaiable Virtual Memory: 1.913GB Avaiable Pagefile: 729.292MB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 30 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-750 - wait... 2 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-750_v0.017_APEONLY_prd.fpsx (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process RM-750_v0.017_APEONLY_prd.fpsx via UBS flashing is good (sometimes is hardly to connect phone but generaly flashing ok) is Nokia 500 Fbus flashing supported? Thanx |
10-29-2012, 21:02 | #4 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i use yellow adapter tx2 enabled in software cable have good connect with all fbus pins on phone, vbat, gnd and bsi inside cable are 2 resistors too 2 Mbus pins joined together what else i must do for flashing start? |
10-30-2012, 13:11 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Don't bother, nokia 500 & 700 you can't flash them using fbus cable with cyclone. You can't even do a check flashing bus. Only usb connection possible for now, tested by me. Luckily we can do all operations via usb (i think, but not tested 100%). BR Renegade |
10-30-2012, 13:35 | #6 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | @renegade i see you allready tried and understand problem, thanx but why support still dont answer? if fbus works, please post log or say "dont supports" |
