05-08-2009, 19:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Local mode final solution for BB5 cables Here the schematics of the add-on box.. It solves: a) BSI problem (add the value of 2,7 or 5.1 to the actual resistor inside the cable) b) Low power problem (using a standard usb charger you can give up to 1 ampere to the mobile ) important when you have not a self powered usb hub or you are using a laptop. Valid solution as well (Using an UFC cable connecting only GND and VPP to the battery connector) to give power to the mobile during an USB flash. BR Alex |
The Following 39 Users Say Thank You to moulnisky For This Useful Post: |
Easy local Mode Final Solution for or UFS/JAF Cables | edcentec | Nokia Base Band 5 ( BB-5 ) | 66 | 12-27-2010 10:10 |
Local Mode Final Solution for or UFS/JAF Cables | moulnisky | Nokia Base Band 5 ( BB-5 ) | 80 | 08-09-2009 07:05 |
Local mode final solution for BB5 cables converter Scenarios | 10xs4asking | Nokia Hardware & Hardware Repair | 0 | 05-17-2009 02:59 |
Local mode final solution for BB5 cables converter Scenarios | 10xs4asking | Nokia Base Band 5 ( BB-5 ) | 0 | 05-17-2009 02:49 |
tma modification Local mode final solution | omkarvitekar | Nokia Base Band 5 ( BB-5 ) | 1 | 05-16-2009 08:49 |
