02-14-2011, 21:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | LOG2COD not found cod Critical Exception While Bruteforce: TryTable full, that means HASH not found, some CRITICAL ERROR! i use 2xRadeon HD5870 in crossfireX and after 4 days i see this error Trying salt 4472 Seconds Remained: 37.4 NCK Not Found Trying salt 6400 Seconds Remained: 37.4 NCK Not Found Trying salt 7904 Seconds Remained: 37.4 NCK Not Found Trying salt 8740 Seconds Remained: 37.4 NCK Not Found Trying salt 4253 Seconds Remained: 37.3 NCK Not Found Trying salt 4730 Seconds Remained: 37.4 NCK Not Found Trying salt 9476 Critical Exception While Bruteforce: TryTable full, that means HASH not found, some CRITICAL ERROR! phone 2730c os win7 64bit Last edited by trt; 02-14-2011 at 21:13. |
02-14-2011, 21:39 | #3 (permalink) |
Member: 197566 Status: Offline Thanks Meter: 89 | all will begin at first maybe this error through that- i start calculate code in one computer and finished in other computer ? does not a version os win7 x64 influence on it ? |
02-14-2011, 22:24 | #5 (permalink) |
Member: 197566 Status: Offline Thanks Meter: 89 | on one PC win7 32bit, 8 codes are calculated and all without errors and on other PC win7 64bit calculate 2 codes and both with errors and sometimes on this PC show error in screenshort: Last edited by trt; 02-14-2011 at 22:33. |
02-14-2011, 22:46 | #6 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 41
Member: 179402 Status: Offline Thanks Meter: 21 | Download this http://golubev.com/files/ighashgpu_v062.zip unrar on the same folder and rename de file |
02-14-2011, 23:46 | #8 (permalink) |
No Life Poster Join Date: May 2009
Member: 1028392 Status: Offline Thanks Meter: 87 | i've got not found few days ago and the second try finished today with not found. I use w7 64bit but i don't think it's problem. Try again and you will see.... don't forget report it here. |
02-15-2011, 00:07 | #10 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote: Check instead it the GPUs temperatures excede the 80° celsius as it makes not really stable the computation. BR Alex | |
02-15-2011, 00:13 | #11 (permalink) | |
Member: 197566 Status: Offline Thanks Meter: 89 | Quote:
so i restart proram with IGHASHGPU v0.80 and delete try file. | |
02-15-2011, 00:20 | #12 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | delete try file and restart the job.. I did a couple of time and the cod been found (once after neither an hour as well) BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
02-17-2011, 13:02 | #15 (permalink) | |
Member: 1028392 Status: Offline Thanks Meter: 87 | Quote:
The first 40 digits are the same. (pixkey use capital letters = no change ) Convert geni/cyclone .log to mxkey hash: Open the log with notepad and keep the first 40 digits only and save it as IMEI.sha Convert mxkey .sha to log for log2cod: 1line:IMEI 2line: take the 40digits from sha file , paste it 8 times and save it as imei.log | |
The Following User Says Thank You to orheiz For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
