10-20-2009, 01:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: heart of fire Age: 45
Member: 156088 Status: Offline Thanks Meter: 9 | my cyclone box cant detect phone...[SOLVED - Thanks PTT] http://forum.gsmhosting.com/vbb/show...708149&page=23 my box is already registered to other name,,not mine...but its no big deal for that matter, but my problem is my box cant detect phone,,i try to connect my 7390,my 6680 and my 1208 nokia phone but undetected. cyclone team,,what is the problem of my box? if i connect my phone to my jaf (w/pkey) using the same cable it was detected and running fine good... is my box have a problem? expexting for an immediate response... thank you so much.... |
10-20-2009, 03:16 | #3 (permalink) |
Member: 156088 Status: Offline Thanks Meter: 9 | here is the logs open/ click dct4/wd2/bb5 Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C000126E HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14 Initializing security card... Card Serial Number: ************* Card Firmware Revision: ******** Card is activated Box is activated Started box selftests procedure USB Voltage 5.10v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work i click READ INFO... a small window or icon display and says this Code: PHONE NOT DETECTED Phone was not detected at FBUS interface even after repowering it. Please power it manually now and click Retry when Local/Testmode woll not appear on phone screen... |
10-20-2009, 03:59 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Which phone you conect to the box ? DCT-4 or BB5 ? Which cable are you using ? Phone goes to LOCALMODE ? are you conecting the phone at Service Socket ? |
The Following User Says Thank You to ptt For This Useful Post: |
10-20-2009, 04:03 | #5 (permalink) |
Member: 156088 Status: Offline Thanks Meter: 9 | that logs is nokia 1208... using 1100 jaf cable(if i connect to jaf using that cable finely good) i connect to diagnostic... and even to my 6680 and 7390 phone same result,same error phone not detected |
10-20-2009, 04:07 | #6 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | You must conect to SERVICE Port not to the Diagnostic ( it is unused for now) |
10-20-2009, 04:08 | #7 (permalink) |
Insane Poster Join Date: Mar 2006 Location: baguio city
Member: 241231 Status: Offline Thanks Meter: 16 | same other phone or not maybe cable problem cyclone need 100%good cable evry u connect phone dead or not |
The Following User Says Thank You to invert For This Useful Post: |
10-20-2009, 04:13 | #9 (permalink) |
Freak Poster Join Date: Jul 2007 Location: murtha
Member: 540170 Status: Offline Thanks Meter: 101 | try to connect the cable directly to service port without yellow adaptor...then post if it can detect phones |
The Following User Says Thank You to sam3578 For This Useful Post: |
10-20-2009, 04:46 | #10 (permalink) |
Member: 156088 Status: Offline Thanks Meter: 9 | finally done tnx a lot. heres the log Code: MCU Version V 03.63 MCU Date 24-10-07 Product RM-303 Manufacturer (c) Nokia IMEI 359562016554012 Mastercode 112076722 IMEI Spare 3A95650261550401 IMEI SV 3395650261550411F2000000 PPM V 03.63, 24-10-07, RM-303, (c) Nokia , H CNT Content: h_red, V 03.63, 24-10-07, RM-303, (c) Nokia , PSN KJQ617897 Product Code 0547037 Module Code 0203414 Basic Product Code 0544850 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 2003 RFIC 064c0609 DSP 07w15pb_07w40.3 LCD SEIKO BT 2222-101B Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF |
10-20-2009, 11:59 | #11 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Glad to see you solve the "problem" . Just remember, for DCT4 & DCT4+ conect phones directly to SERVICE port. For BB5, conect phone to SERVICE port USING the TX2 adapter ( that comes with your box). BR |
10-22-2010, 03:28 | #12 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1424228 Status: Offline Thanks Meter: 0 | maybe you can help me Quote:
How did you solcved this issue man ? I have tried all logic solutions but I keep getting the same error PHONE NOT DETECTED... Please let me know. Regards. | |
problem cyclone box no detect phone [SOLVED] | cystemcel | Cyclonebox | 1 | 12-12-2009 10:49 |
Replaced Cyclone box doesnt detect phones. | desbloqueocelgd | Cyclonebox | 29 | 07-09-2009 05:35 |
Box cant detect phone pin-out? | slyboy_12 | PadFinder box | 1 | 02-28-2009 10:26 |
My new box cant detect any phone ! | Dany | NSPRO | 2 | 11-18-2006 01:41 |
