09-21-2009, 00:36 | #1 (permalink) |
Registered User Join Date: May 2004 Location: QSQ Age: 42
Member: 65987 Status: Offline Sonork: SQSX Thanks Meter: 45 | 1209 Failed to Write UEM? Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... Failed to Write UEM -> Failed to rebuild FLASH data hi dear when i write rpl file so this error comes i cant write rpl file in 1209 plz help me |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 15:17 |
BB5 Unlock Failed -> Failed to write Security Block | sege | Cyclonebox | 1 | 10-26-2009 18:17 |
Failed to Write UEM plz tell me? | abi.m | Cyclonebox | 1 | 08-09-2009 12:05 |
Failed to write eerom to e700 | alifia | UST Pro II | 2 | 02-02-2005 00:26 |
