01-22-2010, 15:21 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 943472 Status: Offline Thanks Meter: 0 | N81 unlock failed [ Solved ] MCU Version V 06wk41v56.1 MCU Date 18-04-08 Product RM-223 Manufacturer (c) Nokia IMEI 356993015413384 Mastercode 4345614662 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E500119488600580602889CAE0936B735885805 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support and selecting Unlock Method... Selected Unlock Method: NCK Code Calculation Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E500119488600580602889CAE0936B735885805 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 BB5 Unlock Failed -> Failed to Boot / Prepare Phone Last edited by ptt; 01-22-2010 at 16:37. |
01-22-2010, 15:49 | #5 (permalink) |
Member: 943472 Status: Offline Thanks Meter: 0 | 2008/2010 MCU Version V 06wk41v56.1 MCU Date 18-04-08 Product RM-223 Manufacturer (c) Nokia IMEI 356993015413384 Mastercode 4345614662 IMEI Spare 3A65990351143308 IMEI SV 3365990351143328F1000000 PPM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 PSN CIN889355 Product Code 0563536 Module Code 0203265 Basic Product Code 0541202 PSD 0000000000000000 LPSN 0 WLAN MAC 001CD437F066 APE SW 20.0.056 APE Variant 20.0.05620.0.056_91.01 APE Test rm223_ENO_x_2007wk24v0.070 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 PCI i20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 UEM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 UPP 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 RFIC 17141715i20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 DSP bruce_mc.ICPR62_08w15i20.0.056j20.0.05620.0.056_91 .01k rm223_ENO_x_2007wk24v0.070n256o256 LCD 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 BT 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP Sw 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP DevID 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP RevID 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 AEM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 Flip MCUSW 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F |
01-22-2010, 16:03 | #6 (permalink) | |
Member: 943472 Status: Offline Thanks Meter: 0 | Quote:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8198 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C0001B7F HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D2000717 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,08v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,03v PASSED VBAT Voltage 4,99v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work | |
01-22-2010, 16:25 | #7 (permalink) |
Member: 943472 Status: Offline Thanks Meter: 0 | solved unlock n81 Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C0001B7F HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D2000717 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,99v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,96v PASSED VBAT Voltage 5,00v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 06wk41v56.1 MCU Date 18-04-08 Product RM-223 Manufacturer (c) Nokia IMEI 356993015413384 Mastercode 4345614662 IMEI Spare 3A65990351143308 IMEI SV 3365990351143328F1000000 PPM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 PSN CIN889355 Product Code 0563536 Module Code 0203265 Basic Product Code 0541202 PSD 0000000000000000 LPSN 0 WLAN MAC 001CD437F066 APE SW 20.0.056 APE Variant 20.0.05620.0.056_91.01 APE Test rm223_ENO_x_2007wk24v0.070 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 PCI i20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 UEM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 UPP 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 RFIC 17141715 DSP bruce_mc.ICPR62_08w15i20.0.056j20.0.05620.0.056_91 .01k rm223_ENO_x_2007wk24v0.070n256o256 LCD 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 BT 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP Sw 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP DevID 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 ADSP RevID 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 AEM 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 Flip MCUSW 20.0.056j20.0.05620.0.056_91.01k rm223_ENO_x_2007wk24v0.070n256o256 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F SX4 Status: Not authorized (76) Started mutual authenthication with card... Cyclone Server (1.0.0.578), Cyclone Box Team 2008, 2009, 2010 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Disconnected from Cyclone Server Failed to Authorize SX4 -> Failed to receive mutual Data 1 from server BB5 Unlock Started... MCU Version V 06wk41v56.1 MCU Date 18-04-08 Product RM-223 Manufacturer (c) Nokia IMEI 356993015413384 Mastercode 4345614662 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E500119488600580602889CAE0936B735885805 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support and selecting Unlock Method... Selected Unlock Method: PM Security Block Calculation Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E500119488600580602889CAE0936B735885805 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... MCU Version V 06wk41v56.1 MCU Date 18-04-08 Product RM-223 Manufacturer (c) Nokia IMEI 356993015413384 Mastercode 4345614662 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! |
HTC dimond 2 unlock fail.....[SOLVED/UNLOCKED] | alternative | FuriousGold | 16 | 01-17-2010 09:19 |
nokia n81 unlock failed | m_tahir1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-14-2010 07:06 |
unlock zte mf 627 unlock fail [SOLVED] | iz7bmw | FuriousGold | 1 | 11-27-2009 13:15 |
N81 RM223 unlock failed [SOLVED] | gilica_gsm | Cyclonebox | 1 | 10-13-2009 14:43 |
n81 unlock problem [SOLVED] | gamesandgrooves | Cyclonebox | 8 | 08-31-2009 19:27 |
