06-21-2011, 17:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: ROMANIA
Member: 727888 Status: Offline Thanks Meter: 219 | N97 Problem flashing with new version ! Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.62, (Jun 5 2011 22:22:07, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00000 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D4000999 Card Firmware Revision: 0109 Card is activated Box is activated Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0FFFFFFF, ONENAND Waiting 640s for erasure finish... Erase taken 1.407s Restarting MCU... BB5 Full Erase Finished! Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-505_22.0.110_prd.core.C00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x0AB9FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.16s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 137.390s Flashing Speed: 6492.94 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.core.C00 (APE)... Processing RM-505_22.0.110_prd.rofs2.V17 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.rofs2.V17, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x079A0000-0x09C9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.235s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 31.875s Flashing Speed: 6307.33 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.rofs2.V17 (APE)... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_507_22.0.110_uda_4_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0ABA0000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.453s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.594s Flashing Speed: 5854.81 kBit/S Restarting MCU... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 12345610654321? SX4 Status: Authorized Disconnected from Cyclone Server Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-505_12345610654321_6212011_74417 PM.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, but writing canceled by user Disconnected from Cyclone Server [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 214 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 376 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 0, Record written NOT OK: 37 SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 214 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 376 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 0, Record written NOT OK: 37 Disconnected from Cyclone Server [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 214 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 376 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [2,0] Written, Length: 448 bytes, Status: OK [4,1] Written, Length: 1020 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,5] Written, Length: 8 bytes, Status: OK [8,7] Written, Length: 4 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 24 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 2 bytes, Status: OK [11,5] Written, Length: 1 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [26,0] Written, Length: 16 bytes, Status: OK [26,1] Written, Length: 68 bytes, Status: OK [31,4] Written, Length: 24 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [50,1] Written, Length: 26 bytes, Status: OK [50,2] Written, Length: 26 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,24] Written, Length: 596 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 944 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [122,0] Written, Length: 2 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [239,0] Written, Length: 2 bytes, Status: OK [239,1] Written, Length: 3269 bytes, Status: OK [239,2] Written, Length: 3269 bytes, Status: OK [239,3] Written, Length: 3269 bytes, Status: OK [291,0] Written, Length: 92 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 [308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [313,0] Written, Length: 173 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [329,0] Written, Length: 8392 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4514 bytes, Status: OK [354,0] Written, Length: 35 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK [372,0] Written, Length: 48 bytes, Status: OK Write PM Finished, Record written OK: 81, Record written NOT OK: 44 SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 10 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 10 bytes, Status: OK [1,7] Written, Length: 214 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 10 bytes, Status: OK [1,16] Written, Length: 208 bytes, Status: OK [1,18] Written, Length: 208 bytes, Status: OK [1,20] Written, Length: 208 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 10 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 208 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 376 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 182 bytes, Status: OK [1,45] Written, Length: 182 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 37, Record written NOT OK: 0 Disconnected from Cyclone Server Started Phone Security Analysis... MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 Reading Security Block... Security block OK and saved to "RM-505_354225036787765_6212011_74913 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F.C0001E00" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! B.R. Last edited by ptt; 06-21-2011 at 23:04. Reason: add CODE tag |
06-21-2011, 21:58 | #2 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Roma (Italy)
Member: 1173993 Status: Offline Thanks Meter: 46 | If you have FULL RPL, after FULL ERASE you have to: 1) Write firmware; 2) Write RPL; 3) Authorize SX4 and write PM1-4-309 (other fields are unnecessary). Check PAPUBKEYS. If after flash is still blank, consider to flash ENO firmware before Stage 1. Bye |
06-22-2011, 06:59 | #4 (permalink) |
Member: 727888 Status: Offline Thanks Meter: 219 | Now after full erase, soft with an older version, write back rpl and pm the phone start up and is working but no lights on display! Code: Initializing FBUS... All initialized - Ready to work Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0FFFFFFF, ONENAND Waiting 640s for erasure finish... Erase taken 1.422s Restarting MCU... BB5 Full Erase Finished! Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_APE_ONLY_ENO_09w23_v0.072.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 3.766s Flashing Speed: 6124.97 kBit/S Restarting MCU... Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-505_22.0.110_prd.core.C00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x0AB9FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.969s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 163.500s Flashing Speed: 5456.05 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.core.C00 (APE)... Processing RM-505_22.0.110_prd.rofs2.V17 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.rofs2.V17, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x079A0000-0x09C9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.234s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 31.891s Flashing Speed: 6304.17 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.rofs2.V17 (APE)... Processing RM-505_22.0.110_C01_prd.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09CA0000-0x0AB9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.141s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.141s Flashing Speed: 523.57 kBit/S Restarting MCU... Processing RM-505_22.0.110_C01_prd.rofs3.fpsx (APE)... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_507_22.0.110_uda_4_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0ABA0000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.453s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.640s Flashing Speed: 5833.51 kBit/S Restarting MCU... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-505_12345610654321_6222011_80544 AM.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 214 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 376 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [2,0] Written, Length: 448 bytes, Status: OK [4,1] Written, Length: 1020 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,5] Written, Length: 8 bytes, Status: OK [8,7] Written, Length: 4 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 24 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 2 bytes, Status: OK [11,5] Written, Length: 1 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [26,0] Written, Length: 16 bytes, Status: OK [26,1] Written, Length: 68 bytes, Status: OK [31,4] Written, Length: 24 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [50,1] Written, Length: 26 bytes, Status: OK [50,2] Written, Length: 26 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,24] Written, Length: 596 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 944 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [122,0] Written, Length: 2 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [239,0] Written, Length: 2 bytes, Status: OK [239,1] Written, Length: 3269 bytes, Status: OK [239,2] Written, Length: 3269 bytes, Status: OK [239,3] Written, Length: 3269 bytes, Status: OK [291,0] Written, Length: 92 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 [308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [313,0] Written, Length: 173 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [329,0] Written, Length: 8392 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4514 bytes, Status: OK [354,0] Written, Length: 35 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK [372,0] Written, Length: 48 bytes, Status: OK Write PM Finished, Record written OK: 81, Record written NOT OK: 44 SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 10 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 10 bytes, Status: OK [1,7] Written, Length: 214 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 10 bytes, Status: OK [1,16] Written, Length: 208 bytes, Status: OK [1,18] Written, Length: 208 bytes, Status: OK [1,20] Written, Length: 208 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 10 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 208 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 376 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 182 bytes, Status: OK [1,45] Written, Length: 182 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 37, Record written NOT OK: 0 Disconnected from Cyclone Server Started Phone Security Analysis... MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 Reading Security Block... Security block OK and saved to "RM-505_354225036787765_6222011_80647 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F.C0001E00" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! MCU Version V ICPR72_09w44.18 MCU Date 28-05-10 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 IMEI Spare 3A45220563877706 IMEI SV 3345220563877716F5000000 CNT 22.0.110.uda_4_001r RM505_RM507_002_000_M014, PSN CUC497264 Product Code 0576560 Basic Product Code 0570816 PSD 0000000000000000 LPSN 0 WLAN MAC 00266856A115 APE SW v 22.0.110 APE Variant v 22.0.11022.0.110.17.0122.0.110.C01.01 APE Test 0.072 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 4001 RFIC |Vapaus_5.1 | Aura_?.? DSP gadget_ICPR72_09w43_p1 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0FFFFFFF, ONENAND Waiting 640s for erasure finish... Erase taken 1.391s Restarting MCU... BB5 Full Erase Finished! Scanning avaiable products... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Processing C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\... Found 2 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-505 - wait... 1 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-505_20.0.019_prd.core.C00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_20.0.019_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x0AB9FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 130.937s Flashing Speed: 6494.08 kBit/S Restarting MCU... Processing RM-505_20.0.019_prd.core.C00 (APE)... Processing RM-505_20.0.019_prd.rofs2.V03 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_20.0.019_prd.rofs2.V03, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x070A0000-0x09C9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.297s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 32.15s Flashing Speed: 6302.53 kBit/S Restarting MCU... Processing RM-505_20.0.019_prd.rofs2.V03 (APE)... Processing RM-505_20.0.019.261.01.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_20.0.019.261.01.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09CA0000-0x0AB9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 1.234s Flashing Speed: 5706.30 kBit/S Restarting MCU... Processing RM-505_20.0.019.261.01.rofs3.fpsx (APE)... Processing RM505_507_20.0.019_uda_1_001.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_507_20.0.019_uda_1_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0ABA0000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.453s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 11.625s Flashing Speed: 5786.80 kBit/S Restarting MCU... Processing RM505_507_20.0.019_uda_1_001.uda.fpsx (APE)... Processing rm505ENOA09w23v0.071.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm505ENOA09w23v0.071.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 3.672s Flashing Speed: 6128.82 kBit/S Restarting MCU... Processing rm505ENOA09w23v0.071.fpsx (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-505_12345610654321_6222011_83509 AM.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21700119BBDA0158E5A7F1CF7164B0DFE71A4A9F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,7] Written, Length: 214 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,22] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,23] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 208 bytes, Status: Not accepted, Code: 19 [1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 376 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,44] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [2,0] Written, Length: 448 bytes, Status: OK [4,1] Written, Length: 1020 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,5] Written, Length: 8 bytes, Status: OK [8,7] Written, Length: 4 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 24 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 2 bytes, Status: OK [11,5] Written, Length: 1 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [26,0] Written, Length: 16 bytes, Status: OK [26,1] Written, Length: 68 bytes, Status: OK [31,4] Written, Length: 24 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [50,1] Written, Length: 26 bytes, Status: OK [50,2] Written, Length: 26 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [96,1] Written, Length: 20 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,24] Written, Length: 596 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 42 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 944 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [122,0] Written, Length: 2 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [239,0] Written, Length: 2 bytes, Status: OK [239,1] Written, Length: 3269 bytes, Status: OK [239,2] Written, Length: 3269 bytes, Status: OK [239,3] Written, Length: 3269 bytes, Status: OK [291,0] Written, Length: 92 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 [308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [313,0] Written, Length: 173 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [329,0] Written, Length: 8392 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4514 bytes, Status: OK [354,0] Written, Length: 35 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK [372,0] Written, Length: 48 bytes, Status: OK Write PM Finished, Record written OK: 81, Record written NOT OK: 44 SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V ICPR72_09w28.6 MCU Date 09-09-09 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 10 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 10 bytes, Status: OK [1,7] Written, Length: 214 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 10 bytes, Status: OK [1,16] Written, Length: 208 bytes, Status: OK [1,18] Written, Length: 208 bytes, Status: OK [1,20] Written, Length: 208 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 10 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 208 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 376 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK Last edited by ptt; 06-22-2011 at 20:25. Reason: add CODE Tag |
06-22-2011, 15:55 | #8 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: ROMANIA
Member: 727888 Status: Offline Thanks Meter: 219 | Quote:
Code: MCU Version V ICPR72_09w28.6 MCU Date 09-09-09 Product RM-505 (Nokia N97) Manufacturer (c) Nokia IMEI 354225036787765 Mastercode 164034710 IMEI Spare 3A45220563877706 IMEI SV 3345220563877706F6000000 CNT 20.0.019.uda_1_001r RM505_RM507_002_000_M014, PSN CUC497264 Product Code 0576560 Basic Product Code 0570816 PSD 0000000000000000 LPSN 0 WLAN MAC 00266856A115 APE SW v 20.0.019 APE Variant v 20.0.01920.0.019.03.0120.0.019.261.01 APE Test rm505ENOA09w23v0.071 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 4001 RFIC |Vapaus_5.1 | ??? DSP ICPR72_09w26 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Selftests to proceed: 51 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_FMTX_TEST Failed ST_DIGIMIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Failed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LED_FLASH_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_TOUCH_STUCK_TEST Failed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Last edited by ptt; 06-22-2011 at 20:26. Reason: add CODE Tag | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
