07-15-2009, 20:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | need some pinout help just got my box , im a bit confused about cables. the adapter who comes with the box ? what it used for ? i have n96 for unlock testing , and soft always give me error while trying to read APE stage.... if i tick skip ape on check , test done np. phone goes to test/local mode with the jaf cable. with the adapter supplyed with the box no conection at all. also from all diag's in here , can i use the original jaf cable with only mod it ? or need 10 make it 10 pins ? thx my 5800 jaf cable gives full test o.k with box |
07-16-2009, 06:45 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The yellow adapter must be used when you work with the bb5 phones. The jaf cables work fine on cyclone but sometime the bsi value is not perfect or you don't get enaugh power from the usb port to manage them. A tool like tma adapter help a lot in having a good local mode. BR Alex |
07-16-2009, 09:17 | #5 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
can you please verify this pinout ? as i see in jaf vpp/tx2 are same cable , and in 10 pin cyclon pin 3 is vpp ? or tx2 also what used the VBUS ? external power ? where is it go in 10 pin of cyclon | |
07-16-2009, 09:53 | #6 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | one this i cant understand ... if jaf cables fit work with cyclon ,i take my n73 cable , and check with jaf Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 50471DFF8FF40605A7F41FAFE7499DE82BA72DA9 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2A60010696D1015490C9D0CE00AF436C1BD454C8 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Done! Restarting phone...Done! all good when i do check with cyclon i always get this error on any ape phone Phone is in Local Mode Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 50471DFF8FF40605A7F41FAFE7499DE82BA72DA9 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2A60010696D1015490C9D0CE00AF436C1BD454C8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 Failed to send APE Secondary Loader -> Failed to get APE Configuration Data Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone also with my N96 when i conect the cable to the yellow adapter , i get no conection to box at all. also this adapter seem to be nothing then extention cable ? nothing in it .. ?? someone please explain |
Need Some Desperate Help - Think I killed my Phone | muzzthegreat | Panasonic | 5 | 10-22-2003 15:32 |
I Need Some Major Help!! | aznlndaghett0 | Samsung Flashers, Software, Firmware. | 2 | 08-01-2003 12:18 |
Need Some Lp Help | mokecke | E-Gold Based Phones | 2 | 03-17-2003 11:13 |
I need some to help me unlock a FISIO in london | saejor | Wanted Products | 0 | 02-19-2003 11:26 |
