Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-10-2015, 15:42   #1 (permalink)
Member: 1537135
Thanks Meter: 1,021
nokia 302 after flash dead
my phone nokia 302 on just update ver 15.15 set dead and info
Failed to read info -> Failed to read SP info plz help me Product Manager
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0007939
HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2011, wk01
Initializing security card...
Card Serial Number: D00B0341
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.12v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.06v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 309.456MB
Avaiable Virtual Memory: 1.875GB
Avaiable Pagefile: 557.1000MB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm813__14.26.mcusw (CMT)...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108
CMT_EM_ASIC_ID: 00001051
CMT_EM_ASIC_ID: 00001060
CMT_PUBLIC_ID: 4C160000FFFB7C402D9D8D3EB3B0B6DF911FC290
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT_BOOT_ROM_CRC: 2CAC45E2
CMT_SECURE_ROM_CRC: 3BC33C8B
CMT Ready!
rm813__14.26.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
Searching for BootCode: DualLine 32Bit
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000131, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000131, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x000403FF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, ONENAND
EraseArea[0,CMT]: 0x00140000-0x004BFFFF, ONENAND
EraseArea[0,CMT]: 0x004C0000-0x0073FFFF, ONENAND
EraseArea[0,CMT]: 0x00740000-0x0147FFFF, ONENAND
EraseArea[0,CMT]: 0x00160000-0x0017FFFF, ONENAND
EraseArea[0,CMT]: 0x03200000-0x0387FFFF, ONENAND
EraseArea[0,CMT]: 0x0F080000-0x0F67FFFF, ONENAND
EraseArea[0,CMT]: 0x01480000-0x0243FFFF, ONENAND
EraseArea[0,CMT]: 0x02440000-0x025BFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.610s
Writing all blocks...
TurboCache Loaded!
Writing CMT KEYS Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT MCUSW1 Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT ISA+DYNSW Certificate...
Writing CMT ADA Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT ISA+EXTDRV Certificate...
Programming Status OK!
All blocks written OK! Time taken 4.875s
Flashing Speed: 54803.21 kBit/S
Processing rm813__14.26.mcusw (APE)...
Processing rm813__14.26.ppm_ma3 (CMT)...
rm813__14.26.ppm_ma3, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x025C0000-0x031FFFFF, ONENAND
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 0.672s
Flashing Speed: 68597.58 kBit/S
Processing rm813__14.26.ppm_ma3 (APE)...
Processing rm813__14.26.image_ma3_059K7R0_059N7S7_529_01 (CMT)...
rm813__14.26.image_ma3_059K7R0_059N7S7_529_01, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x03880000-0x0F07FFFF, ONENAND
Erase taken 2.234s
TurboCache Loaded!
All blocks written OK! Time taken 3.890s
Flashing Speed: 59934.35 kBit/S
Processing rm813__14.26.image_ma3_059K7R0_059N7S7_529_01 (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
[Generic Phone]: Port opened OK!
[Nokia Asha 302 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version V 14.26
MCU Date 23-01-12
Product RM-813 (Nokia RM-813)
Manufacturer (c) Nokia
IMEI 356335059318592
Mastercode 6046226222
IMEI Spare 3A65330595135809
IMEI SV 3365330595135809F4000000
PPM V 14.26, 23-01-12, RM-813, (c) Nokia , MA3
CNT Content: ma3_059K7R0, V 14.26, 23-01-12, RM-813, (c) Nokia
PSN 0
PSD 0000000000000000
LPSN 0
WLAN MAC ECF35B49DA9B
RETU 51
TAHVO 00
AHNE 21
RFIC |Alli_4.3.4
DSP 104_MP5.2_14.26
LCD TPO
BT 4217-v924
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Setting factory defaults of: Factory set full
Factory defaults set OK
Processing 5901B58F_rm813__15.15.mcusw (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
5901B58F_rm813__15.15.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
Erase taken 0.594s
TurboCache Loaded!
All blocks written OK! Time taken 4.860s
Flashing Speed: 55005.22 kBit/S
Processing 5901B58F_rm813__15.15.mcusw (APE)...
Processing D0318CD3_rm813__15.15.ppm_c5 (CMT)...
D0318CD3_rm813__15.15.ppm_c5, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 0.703s
Flashing Speed: 68871.08 kBit/S
Processing D0318CD3_rm813__15.15.ppm_c5 (APE)...
Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (CMT)...
42EDF42D_rm813__15.15.image_c5_059K7T6, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
Erase taken 1.484s
TurboCache Loaded!
All blocks written OK! Time taken 3.594s
Flashing Speed: 60299.50 kBit/S
Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version V 15.15
MCU Date 05-06-13
IMEI SV 3365330595135819F5000000
PPM V 15.15, 05-06-13, RM-813, (c) Nokia , C5
CNT Content: c5_059K7T6, V 15.15, 05-06-13, RM-813, (c) Nokia
PSN 0
LPSN 0
RETU 51
TAHVO 00
AHNE 21
RFIC |Alli_4.3.4
DSP 104_PM5_15.15
LCD TPO
BT 4217-v924
Old 02-11-2015, 10:24   #2 (permalink)
Member: 1537135
Thanks Meter: 1,021
plz help me any one .....................
Page generated in 0.19688 seconds with 8 queries
