01-07-2014, 10:11 | #1 (permalink) |
Crazy Poster Join Date: Jun 2013
Member: 1957672 Status: Offline Thanks Meter: 11 | Nokia 301 can not falsh Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19 Initializing security card... Card Serial Number: Card Firmware Revision: Card is activated Box is activated Started box selftests procedure USB Voltage 4.94v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 96 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.869GB Avaiable Pagefile: 3.702GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm839__02.33.mcusw (XGold2)... Checking rm839__02.33.mcusw... Flash file sorted Okay. 8 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to process Image File -> BootROM not detected! Failed to Process all Image files -> Failed to process Image File Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm839__02.33.mcusw (XGold2)... Checking rm839__02.33.mcusw... Flash file sorted Okay. 8 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to process Image File -> BootROM not detected! Failed to Process all Image files -> Failed to process Image File Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm839__02.33.mcusw (XGold2)... Checking rm839__02.33.mcusw... Flash file sorted Okay. 8 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia 301 USB Phonet]: Port opened OK! Switching to RAW Mode... PS : USB device not found also, may be it high bootloader |
