03-29-2010, 23:45 | #16 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | 1º Go to BB5 / security tab, and do an SX4 Authorize 2º Once you get authorized, go to Common / Info tab and write PM ( make sure you dont have thicked SX4 Bypass ) Here you have a "Step by Step" guide: http://forum.gsmhosting.com/vbb/5576487-post2.html Read carefully...... BR |
03-29-2010, 23:47 | #17 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Spain
Member: 556522 Status: Offline Thanks Meter: 7 | i have those file stored : RM-159_358064012216333_29032010_11338.SecurityBlock.P M _358064012216333_29032010_23425.SLBackup.PM RM-159_35806401221633329032010_23410.RPL |
03-29-2010, 23:48 | #18 (permalink) |
Member: 556522 Status: Offline Thanks Meter: 7 | selftest logs: Setting factory defaults of: Factory set full Factory defaults set OK Selftests to proceed: 43 Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_EXT_DEVICE_TEST Failed ST_CDSP_RF_BB_IF_TEST Failed ST_CDSP_RF_SUPPLY_TEST Failed ST_CDSP_TX_IQ_TEST Failed ST_CDSP_TXC_DATA_TEST Failed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_WCDMA_TX_POWER_TEST Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_IR_LOOP_TEST Failed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_ACCEL_IF_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_APE_EM_ASIC_TEST Passed ST_TEMP_SENSOR_IF_TEST Passed ST_VIBRA_TEST Selftests done, Tests total: 43, Tests passed: 30, Tests not passed: 13 |
03-29-2010, 23:53 | #19 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | You must download the Alex PM collection http://forum.gsmhosting.com/vbb/5640036-post6.html, in the zip file you found a file named " RM-159.pm" that is the file you must extract and write to your phone. BR |
03-30-2010, 00:04 | #20 (permalink) |
Member: 556522 Status: Offline Thanks Meter: 7 | Oh my *** its alive: After i read this manual Ive realize where I was wrong and now is starting up normaly. http://forum.gsmhosting.com/vbb/5576487-post2.html I will test it next days to see if is stable , the camera is working fine. Thanks to all . I love Cyclone box. Keep it this way ur doing a good job. |
Nokia N95 rm159 phone start-up failed contact the retailer. | faizanbhatti94 | Nokia Base Band 5 ( BB-5 ) | 6 | 04-08-2010 08:47 |
5700 phone start-up failed contact the retailer[SOLVED] | beo_tech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-07-2010 14:13 |
n73 phone start-up failed.contact the retailer [SOLVED] | jak2812 | Cyclonebox | 18 | 09-21-2009 08:08 |
Nokia N95 8g PHONE START UP FAILED CONTACT THE RETAILER | biscotte64 | Nokia Base Band 5 ( BB-5 ) | 9 | 08-22-2009 20:54 |
