07-07-2011, 14:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jind
Member: 998896 Status: Offline Thanks Meter: 15 | what is problam?? in cyclone box here is log.. Code: handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.64, (Jun 30 2011 15:31:22, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00059EB HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44 Initializing security card... Card Serial Number: D00804F8 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.94v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.75v PASSED VBAT Voltage 1.34v PASSED VBAT Voltage 4.90v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 320 products, Filtering BB5 Products - wait... Failed to Substitue INI Variant Data -> Access violation at address 0061F218 in module 'Cyclone.exe'. Read of address 00000000 200 Products left after filtering. Ready. Retrieving Variants for Product - wait... Failed to retrieve BB5 Variants -> Unexpected error, no VPL or neither INI files found inside Product Directory Retrieving Variants for Product RM-237 - wait... 3 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-237_356789022577843_772011_70918 PM.SecurityBlock.PM" "276001056B4C7C56AF2052F88CD8F118719CC28B.C00059EB" Exists, That is good... Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 276001056B4C7C56AF2052F88CD8F118719CC28B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898981 (Intel), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... Storing VARIANT... Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V 07.30 MCU Date 07-05-09 Product RM-237 (Nokia 3110c) Manufacturer (c) Nokia. IMEI 356789022577843 Mastercode 2562105134 Simlock backup OK, saved to RM-237_356789022577843_772011_70945 PM.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm237__07.30.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 276001056B4C7C56AF2052F88CD8F118719CC28B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm237__07.30.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898981 (Intel), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 95.656s Writing all blocks...:confused: Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm237__07.30.mcusw Last edited by ptt; 07-07-2011 at 16:09. Reason: add Code Tag |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
