07-11-2009, 19:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: GB Age: 54
Member: 24791 Status: Offline Thanks Meter: 35 | Only liting RM-78 in products Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 4 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. N91-1 connected but only shows RM-78 in Product tab? |
07-11-2009, 20:08 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Select the files manually.. the actual version filter is really selective as it doesn't work on the ini files. next one will be perfect... BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-12-2009, 05:04 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | its nto a BUG its just that the Current Version can only scan VPL files only. So older products, which using old "INI" way is not detected here but it will be Fixed in major Update |
Need Nokia 6288 V 06.10 RM-78 product codes for europe or middle east | breal | Nokia Base Band 5 ( BB-5 ) | 3 | 11-28-2007 13:28 |
Does unlocking 6288 RM-78 is the same as 6280 RM-78 | samuelscu | BB5BOX | 0 | 09-24-2007 21:49 |
RSD Lite 3.4 only connects to Z3 in flash mode - need flex clock-fix. | Jazz | Motorola P2k | 1 | 02-28-2007 18:07 |
6280 RM-78 Flashing Russian on it | drancill | Nokia Base Band 5 ( BB-5 ) | 0 | 02-27-2006 19:29 |
