09-18-2012, 08:40 | #1 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | Please Help. i Cant use Box Wizzard... [Solved] Failed to launch box in Main Mode. Main Firmware wasn't flashed during this session. Possible cause: empty firmware, demaged hardware (crystals), damaged security area, drivers problem, OS problem, etc. Service Tag was copied to clipboard. This is my Cyclone Box Service Tag: BF21CBE49676BCBED1B792BBA994C177... Wath is the solution for this ? thx for help.. |
09-18-2012, 10:58 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
The Following User Says Thank You to kaisak For This Useful Post: |
09-18-2012, 11:11 | #3 (permalink) |
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | Thx problem solv.. Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002384 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D40003A5 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.06v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.02v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.141GB Avaiable Virtual Memory: 1.788GB Avaiable Pagefile: 3.324GB Initializing FBUS... All initialized - Ready to work |
