07-06-2009, 15:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 682820 Status: Offline Thanks Meter: 24 | pleassssssss hilpe me Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0000B13 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D2000097 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.79v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.80v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.75v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting RAP... Failed to Read ASK via Flash Bus -> RAP Not Responding Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: E0ADA605BA183AB606D24A20A5B691C399CED49B APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21600113BA6B0058682DE5974D5DF33F69E45580 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! omap2420_m1_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.41.0, Algo: BB5 Failed to send APE Secondary Loader -> Failed to get APE Configuration Data Failed to Read All Certificates -> Failed to Boot / Prepare Phone Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-159_31.0.017_PR.C0R (CMT)... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: E0ADA605BA183AB606D24A20A5B691C399CED49B APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21600113BA6B0058682DE5974D5DF33F69E45580 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RM-159_31.0.017_PR.C0R, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x007B163D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.109s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM-159_31.0.017_PR.C0R Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-159_31.0.017_PR.C0R (CMT)... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: E0ADA605BA183AB606D24A20A5B691C399CED49B APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21600113BA6B0058682DE5974D5DF33F69E45580 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RM-159_31.0.017_PR.C0R, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x007B163D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.109s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM-159_31.0.017_PR.C0R Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-159_31.0.017_PR.C0R (CMT)... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: E0ADA605BA183AB606D24A20A5B691C399CED49B APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21600113BA6B0058682DE5974D5DF33F69E45580 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RM-159_31.0.017_PR.C0R, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 10 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x007B163D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.109s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM-159_31.0.017_PR.C0R Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-159_31.0.017_PR.C0R (CMT)... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: E0ADA605BA183AB606D24A20A5B691C399CED49B APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 21600113BA6B0058682DE5974D5DF33F69E45580 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RM-159_31.0.017_PR.C0R, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x007B163D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.110s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM-159_31.0.017_PR.C0R ================================================== == i cont flash a dead phone and i dont now hwo to put the cable of phone in each com |
07-06-2009, 18:38 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | plz use adaptor frist and use com port service and cable 7 pin its all br cyclone teem |
The Following User Says Thank You to amralkareem For This Useful Post: |
07-07-2009, 01:05 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | OK... start with downloading this update http://rapidshare.com/files/24744090...one7828NCK.rar and unzipping the files in you c:\program files\Cyclone box folder answering yes when asked to overwrite.. actually you are working with the new firmware and the old version of the software.. thing not good at all. :-) Second thing: you MUST use the tx2 adapter (The yellow cable included in the box) when you work with BB5 mobiles and the N95 is one of them. Fix this two points and report the logs.. :-) BR Alex |
07-07-2009, 08:50 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | I recommend First Check Flashing bUS to see if all is OK with Phone and Cable then proceed ... Also this will make phone to become in needed mode...if Cable is well modified |
07-07-2009, 16:58 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | 3110 is not RM159 but RM-237 Print here the info and the self test of the phone please BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-12-2009, 18:01 | #10 (permalink) |
Member: 682820 Status: Offline Thanks Meter: 24 | All initialized - Ready to work Failed to read info -> Phone not detected Failed to read info -> Phone not detected Failed to read info -> Phone not detected ============================== i cont read info from n79 pleaseeeeeeeeeeeee its veryyyyyyyyyyyyyyyyyy bad box |
07-12-2009, 19:05 | #11 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | It's ccable problem, correct your bsi resistor, otherwise no box avaiable in market will scan your phone via fbus interface. |
07-13-2009, 09:08 | #12 (permalink) |
Member: 682820 Status: Offline Thanks Meter: 24 | what???? i trid eviry think ii chinched the cable and with ac or with out ac i trid another com port another computer and no think if there ( local mod ) or ( tist mod ) it will be ok no local no tist thine no solution to do any work |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
Help me Pleasssssssse | malangbaba | LG Hardware Repair | 0 | 10-30-2008 10:01 |
who to unlock a70 hilp me | subhdra | E-Gold Based Phones | 8 | 09-29-2007 15:17 |
who to flash u8330 in ufs piles hilp me | subhdra | LG | 0 | 09-18-2007 20:11 |
pm 3230 pleassssssss | alshahbandar | WD2 & APE (Symbian Phones) | 3 | 07-08-2007 15:18 |
