Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-20-2012, 15:12   #1 (permalink)
Member: 808204
Sonork: eagleyezzz
Thanks Meter: 2
C1-01 not reading further ... any solution sir ?
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0004406
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01
Initializing security card...
Card Serial Number: D0020525
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.99v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.83v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.894GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 27 products, Filtering BB5 Products - wait...
11 Products left after filtering. Ready.
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Sending User Abort Signal...
Phone not detected at USB -> User Abort
Proceeding with Recovery Mode...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Recovery Mode Failed, storing Certificates Only
Booting CMT...
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm607__06.15.mcusw (XGold2)...
Checking rm607__06.15.mcusw...
Flash file sorted Okay.
1 file(s) embedded into image.
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
X-Gold: Ready, MCU ID Block: 1FB300020603010100FF
[PBL] : Ready
first time it was flashed OK but second time .....
need help
thanx
Old 09-20-2012, 21:38   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
check usb cable , use another usb port .
Page generated in 0.13659 seconds with 8 queries
