View Poll Results: add new gpu ati 6xxx in log to code | |||
yes | 442 | 91.70% | |
no | 43 | 8.92% | |
Multiple Choice Poll. Voters: 482. You may not vote on this poll |
11-01-2011, 21:37 | #991 (permalink) |
Freak Poster Join Date: May 2006 Location: U.S.A.
Member: 285890 Status: Offline Thanks Meter: 72 | |
11-02-2011, 07:12 | #993 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | If the bios don't help it means one of the 2 cards has not OC capabilities (not able to apply the voltage regulation of the gpus). In this scenario you can't set the cards at a speed over 900 mhz (most stable 850) BR Alex Note: Both the cards must work at the same speed |
11-03-2011, 10:29 | #994 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | How to add a sound at the end of the bruteforce Been asked in PVT this question and I thought may be usefull for the other users too Just download and install this little exe http://www.mustang.co.za/exe/PlaySoundSetup.exe once installed copy playsound.exe and tada.wav (you can find it in c:\windows\media) in the oclhashcat-lite folder after each bf-line add the command playsound tada.wav job done BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
11-06-2011, 21:41 | #995 (permalink) |
Insane Poster Join Date: Jun 2010 Location: Cuba Age: 36
Member: 1318109 Status: Offline Sonork: Guille® Thanks Meter: 12 | Cross Fire Help .... AMD 990FX Sabertooth Hello friend helps Cross Fire Set Sabertooth 990FX AMD ATI 5970 ..... I need to know how to set the cores to achieve higher performance |
11-06-2011, 22:28 | #996 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi Alex, Can you tell me which is the best performance with 2 x 6990 in crossfire please ? I run with the last version of Catalyst HD 69xx drivers and now the VGA running at 50° C with watercooling system. Its a good temperature ? Best regards, Dany |
11-06-2011, 23:45 | #997 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
I get the best stability with these values Core voltage : 1120 Core Clock : 924 Memory Clock : 800 Cheers Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
11-07-2011, 03:50 | #998 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote:
As I told you at the PM...here is the image of the temperatures. Regards, | |
11-07-2011, 08:53 | #999 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | I have a problem. I beleave is the temperature problem what turn off my computer at 1 or 2 hours. I take out 1 of 6990 and test. Work fine with 50° but at 1-2 hours the pc is turn off again. Now I replace the 6990 for the other and test it again. Before installed the watercooling sys the pc is well with 78° and with a two 6990 coolers. I dont know what happend. Any sugestion please ? Many thanks |
11-07-2011, 09:56 | #1002 (permalink) | |
Carefull if you connected the Fans to the maiin board as some mobos have problem if too much amperes are taken off the fans pin BR Alex | |
11-07-2011, 10:07 | #1003 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Maybe the problem comes from something bad I did to put the fullcover ? The thermalpads etc? With the 2 VGA the PC is turned off. Once again I turned off ! With the 2 6990 is the same ! After 1 hour is turned off. The aditional coolers and watercooling are connected to the PSU directly. The funny thing is that it was after installing the cooling system began to happen this. br |
11-07-2011, 10:18 | #1004 (permalink) | |
The temps are fine for what I can see so looks like the job been done well but, obviously, is only a first impression look. Download and install GPUz and, using it, monitor in all the cards thevalues on the diferent parts of the cards (VRMs, memory etc.) as temps.. may be there is a problem with the cooling of part of the cards Cheers Alex | |
11-08-2011, 22:10 | #1005 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi Alex, Can you tell me if it is possible that the PC is turned off because the frequency between the GPU was configured differently between the two? I did not notice that detail ... Now, is working well. Now I put the 2 GPU Clock in 850Mhz and Memory Clock in 1250 Mhz each one. I tested each of the 6990. regards, Dany |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
