Problem with new cuclone key ! [ solved ] try to update with box wizard always critical error! Install latest setup but i can t upgrade box always error ! B.R. |
I think will be good give here log from operation becsoue without this noone will give you correct answer. |
Me too. im buy cyclone box reloaded 2 hr ago. cant update, critical error. i dont know serial N, this is absolutely new box. ????? help me pls! logs??? just critical error, no logs... cant connect server... |
First when i double click on cyclone box shortcut i get :cant creat navifirm landing zone, please check application privileges ! Then i click on box wizard and i get this error boot agent didnt sent secure data Finished with critical error ???? B.R. |
If you use windows vista/7/8 need run software with admin right. |
absolutely new box. never connect, never use. Windows XP SP3, start as admin. cant update. :( I dont have 10 msg to send screenshot. |
WOW! my box registered now. thanks cyclone team :) Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: xxxxxxxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5,10v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,05v PASSED VBAT Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 513.852MB Avaiable Virtual Memory: 1.882GB Avaiable Pagefile: 1.985GB Initializing FBUS... All initialized - Ready to work |
For me same problem .... screenshot below ERROR CYCLONE KEY | Fisier - Upload Videos, Images, Music Yourself. Could anyone please help me? B.R. |
Just wain 1-2 hour. Im just registered now. I have this error, but now im sucsess registered and my box ready to work! |
Those errors ? First when i double click on cyclone box shortcut i get :cant creat navifirm landing zone, please check application privileges ! Then i click on box wizard and i get this error boot agent didnt sent secure data Finished with critical error ???? B.R. |
Create Landing Zone manually or run application as Administrator (right click and select Admin). Install all drivers for box. Wait 1-2 hour and start Box Wizard. |
How to create landing zone manually? |
go to program files / cyclone box / StoredFiles and make folder LandingZone manually for win7 x32, Win XP |
I already have LandingZone folder there. What the f.... is the problem? |
