04-14-2012, 10:39 | #242 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Badong's Junkshop
Member: 260632 Status: Offline Thanks Meter: 639 | im facing the same problem cant connect cyclone server editing host etc still the same .. is there problem connecting server her in philippines ? br |
04-14-2012, 10:41 | #243 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | It should be ok now. It is also possible you pasted wrong IP in your HOSTS file and you will not be able to connct to server anymomre (apart from deleting line again). |
The Following User Says Thank You to karwos For This Useful Post: |
04-14-2012, 11:01 | #245 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
Maybe because like a lots of ppls write n hosts "cyclone.karwosgsm.p" instead "cyclone.karwosgsm.pl"... | |
04-14-2012, 11:10 | #246 (permalink) | |
Member: 260632 Status: Offline Thanks Meter: 639 | Quote:
br | |
04-14-2012, 11:40 | #247 (permalink) |
No Life Poster Join Date: Nov 2008 Location: SKY Age: 78
Member: 910577 Status: Offline Thanks Meter: 242 | HI CYCLONE TEAM all done thanks for the great great help u r all great server working fine and all update done 5***** to hole team keep it up please help to all cyclone user thankssssss |
04-14-2012, 15:02 | #248 (permalink) |
No Life Poster Join Date: Oct 2011 Location: worldwide
Member: 1677015 Status: Offline Thanks Meter: 53 | Hello team! After edit host i can update box and check my credit but for iphone ckecker i have this message Started credits checking procedure at 13:57:38 Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Service Tag: 9D3502C130FB8DB1EA54FF207C230F06 Cyclone Server (2.0.0.5), Cyclone Box Team 2008-2011 - Ready. Credits: 100 iPhone Check started for IMEI 01242700xxxxxxx Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Please Wait... Cyclone Server (2.0.0.5), Cyclone Box Team 2008-2011 - Ready. Cyclone Server Send Command Error -> Code: 500, Access violation at address 004252AB in module 'CycloneServer.exe'. Read of address 00000001 Failed to Check iPhone -> Command Send failed |
04-14-2012, 15:28 | #249 (permalink) |
Member: 1677015 Status: Offline Thanks Meter: 53 | All work now after this # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 83.19.176.83 cyclone.karwosgsm.pl # source server 127.0.0.1 localhost |
04-24-2012, 15:54 | #252 (permalink) |
Junior Member Join Date: May 2007
Member: 511137 Status: Offline Thanks Meter: 0 | Box Maintenance Error -> Can't connect to Cyclone Server Hi i have tired every thing but no luck need help. Thanks Box Maintenance procedure started at 15:53:42 Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: AA9C2049BD03761E1539E3D86901E600 Connecting to Cyclone Server Box Maintenance Error -> Can't connect to Cyclone Server |
04-24-2012, 22:04 | #254 (permalink) |
Member: 910577 Status: Offline Thanks Meter: 242 | hi sir same not working try to do every thing but same Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0007432 HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19 Initializing security card... Card Serial Number: D00F01A9 Card Firmware Revision: 010A Initialization has failed -> Security Card is expired after this if team says i do this Box Maintenance procedure started at 10:07:31 PM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Classic Common Bootloader v3.00, (Apr 6 2012 16:14:55) Service Tag: 10B887DBD48A83555B01ABD3CC1F7B60 Connecting to Cyclone Server Cyclone Server (2.0.0.19), Cyclone Box Team 2008-2012 - Ready. ========= Box Info ========= Box SN: C0007432 HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19 Set: Classic Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D00F01A9 First Name: ali Surname: xxxxx Nickname: xxxxxxx Country: uk E-Mail: xxxxxxxxxxxxxxxxxx Reseller: Fonefunshop, UK Warranty Start Date: 2012-04-06 Warranty Period (months): 6 Warranty Stop Date: 2012-10-06 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating COM Emulator Firmware... COM Emulator Update Skipped, Not allowed Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41 Bootloader is already Up-to-date Secure Bootloader Update Skipped Disconnected from Cyclone Server Box Maintenance finished successfully |
04-25-2012, 14:22 | #255 (permalink) |
Insane Poster Join Date: May 2003 Location: NORTH LONDON Age: 50
Member: 28528 Status: Offline Thanks Meter: 2 | problems with credit activation ok i am having problems activating my super/dct4 credit problem with server please tell me what my problems is please refer to pic thanks in advance !! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
